Question about Dymo LabelWriter 400 Thermal Printer
A piece is stuck the lable is stuck. - Dymo LabelWriter 400 Thermal Printer
    Problem Solver:
  • 13 Answers
Where is it stuck? How far inside?
Posted on Apr 09, 2008
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Right speaker has no sound
Check R cable from source to speaker, No power used in L or R cable, they only receive the signal from SOURCE to speaker, You onlly have 2 ends of each cable, 1 to source other end to speaker
Mar 13, 2015 | JBL Pebbles 2.0 Speaker System 2-Piece
I have a Brother GX-6750 correctrone that won't
If you can roll it in by hand but ie won't advance you most likely have a cracked gear on the index motor. If the pa[er won't go in at all you may have a lable stuck. Try feeding and pushing thin piece of card board thru/
DickyO
Aug 23, 2013 | Office Equipment & Supplies
Activation key for windows 7?
If you have a genuine copy of windows, your activation key will either be a piece of card that came with the discs, or on a sticky lable affixed to the computer. Otherwise i'm afraid you will need to purchase a key from microsoft.
Oct 17, 2010 | Microsoft Computers & Internet
CombBind C450e binding machine. How did I get the top off? A piece fell off inside and I cannot get the top off.
the top is connected with 7 star shaped screws look in the back of the machine you will see the exact shape. in the back there are 3 screws then there are 2 more screws on every side under the dark grey lable on is located on the very bottom (lift the lable you will find it) to find the other 2 slide your finger on the grey lable you will feel a small round hole on the right side it is about a cm under the **** where the papers get punched and on the left side it is about 3 - 4 inches under that ****. Good luck
Aug 27, 2010 | Ricoh FAX3900L Plain Paper Laser
I printed up lables and one of my labels stuck to
Turn it on, allow it to home, mark the printwheel with some white out.
Turn it off and on a few times if the mark dosen't always return to the same place the homing pawl is broken, you need a tech.
DickyO
Jun 04, 2010 | Brother Office Equipment & Supplies
I can't take out the dvd from the drive as that is not ejecting
you may have a label or even the metal slide piece stuck in the mechanism. Take it to a computer shop so you dont do more damage trying to open it. Some CD drives have a small reset hole on the front that when an open paper clip is inserted it allows rejection but if a lable is stuck it needs specialized intervention, especially for the 3.5 drive that has metal slide from disk jammed in it
May 18, 2010 | Acer (91.47A37.001) CD-ROM Drive
CDJ 800 MkI. When I put in a CD, it makes a sound
Bits of paper / pieces of CD lables can get stuck inside and rub on the CD causing the noise you are hearing
http://stores.ebay.co.uk/methleykev
May 10, 2010 | Pioneer CDJ-800 Turntable
I HAVE AN OLD RIDE ON LAWN MOWER LABLED AS MOUNTFIELD 7 WITH A 25 LABLE ON THE FRONT I BELIEVE ITS APPROX 1978 AND I NEED A DRIVE V BELT FOR THE BLADE OR A PART NUMBER
if you have the old belt take it with you to a local parts store. if you don't have the old one, then take a long piece of cord and run it around the pully's the way it should go and tie it to the right size ( or atleast close it it) and take that to the parts stor and get a belt that size you can adjust the tension when you get it back on...good luck
Apr 01, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Same problem
Jun 21, 2009 | Acer (91.AB264.023) Internal 32x CD-ROM...
Dymo LabelWriter 400 Thermal Printer Logo
66 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
