Question about Toastmaster 1183N Bread Maker
I accidentally unplugged it, I have about 2 hours left on the baking cycle. What should I do?
Does the bread mahine turn off when done if i am no here
Yes it does, but after half an hour the bread will go soggy.
Jun 07, 2014 | Oster 5838 ExpressBake Bread Maker
Freezer door was accidentally left open for about one hour. Now the refrigerator and freezer are not cooling.
If the freezer or fridge door remains open for one hour or few more hours by mistake, then to again get to its proper cooling cycle, it requires approx another 24 hours.And in that also, dont open the refrigerators doors for few hours.If you open, close it quickly.Once it cooling cycle again gets set, then you can use it like you use regularly.But approx it takes 24 hours to get proper cooling.-------- ------------------ But if its already more then 24 hours and there is very low cooling, then it can be internal defrost cycle issue.You will have to do manual reset procedure.The manual reset procedure is as follows:-------- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check,it will get set to its cooling cycle and work as normal.------------- This should help.Thanks.Helpmech.
May 04, 2011 | Refrigerators
My bread machine was unplugged with about 20 left in the bake cycle. How do I get it to go bake into the bake cycle. Display panel is unlit
If your machine has a "Bake" cycle then choos that cycle and push start and adjust the timer so it cooks the right length of time. Your manual should tell you how long the the last bake cycle takes and just push your timer until that time is set less the 20 minutes already baked.
Nov 05, 2010 | Oster 5834 ExpressBake Bread Maker
My machine was unplugged for no more than 3 seconds during kneading. it is quiet now and on ALERT. on a 5 hour whole wheat xl loaf..now at 3:02. how do i restart it and move it off of alert
If you feel your dough has kneaded and risen enough, try pushing the stop button until it beeps. Then unplug and replug and select the bake stage and using the timer feature put enough time on the bake cycle to equal the bake time of your original whole wheat bake stage. That time should be on your page in the manual that shows the length of all the programs.
Oct 28, 2010 | Panasonic SD-YD250 Bread Maker
My ABM 6000 machine was accidentally unplugged near the end of the rise cycle. Can it be set to finish. When I restarted it it began kneading the dough again.
If you feel your dough has risen enough (look at your cycle times and estimate how long it was into the rise) and if so you could set your machine to the "bake" cycle and then click the timer button in 10 min. increments until it is set to bake the right amount of time. Maybe this will work. Hope it does!
Oct 28, 2010 | Welbilt Kitchen Appliances - Others
Amana electric oven won't get above 225 degrees. Takes over an hour to get to this temp.
sounds like only the broiler is working which comes on low during bake cycle. unplug or turn off breaker, remove bake element and check for continuity or take to someone who can.
Jun 13, 2009 | Amana AER5725QA Electric Kitchen Range
Breadmaker not finishing the cyle
If you are leaving the unit plugged in all the time, you may reset it by unplugging it for about half an hour.  If this doesn't clear the problem, the timer unit is bad and will likely need replacement.  If you like the unit, consider a new one...or another brand
Nov 23, 2008 | Breadman TR2200C Ultimate Bread Maker
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Toastmaster 1183N Bread Maker Logo
44 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
