Question about Sony Playstation 3 (PS3) Console
The PS3 will not power on - Sony Playstation 3 (PS3) Console
    President:
  • 1,382 Answers
Most of the times, you're going to find that this is due to over heating. If you've been playing for a while, shut down your Playstation, and let it sit for about 1 hour. It's best if the room is cooled off as well.If the room is hot, you may want to put a fan blowing toward it, or turn up your Air Conditioning.Check the back of your unit, and make sure that all of the cables are plugged in. What you're going to want to do is take out each one, and blow the inside of the ports with compressed air.
To play it safe, take out the Playstation's hard drive, and place it back in.Once the 1 hour is up, and the Playstation hasn't been running, turn it back on, and see if everything is working. If it is, you're good to go! If it isn't, you may want to consult with Sony.
Thank you !!
Posted on Jun 03, 2010
Can the power supply on a PS3 be tested
Yes, best thing to do would be to go to a buyback games or check locally for information on testing a PS3 power supply.. Or you can google: How to test a PS3 power supply. good luck.
May 07, 2014 | Sony Official Playstaton 3 PS3 Power...
PS3 320gb Slim No Power (No Lights)
You could always try a system reset:
Starting with the PS3 off... Hold Power button on PS3 for 10 seconds. When you hear the second beep, it has been reset...
May 20, 2012 | Sony Playstation 3 (PS3) Console
How do you reset your PS3?
You can reset the Sony PlayStation 3 to troubleshoot the gaming system or restart after a hard drive freeze. Resetting the PS3 will restore the PS3's settings to to the default factory settings. Consider backing up any data or custom settings before doing a system reset for the PS3 as they might be erased.
instructions:
  • urn off the PS3 by flipping the power switch on the back of the system.
  • 2
    Turn the power switch back to the "on" position.
  • 3
    Hold the power button while the PS3 is powering up until you hear three beeps. These signal that the PS3 has received the manual system reset command.
  • 4
    Prompt through the initial setup menu to continue resetting the PS3.
  • 5
    Select "Format" from the system menu to format and finish a complete system reset for the PS3.
  • Dec 06, 2011 | Sony Playstation 3 (PS3) Console
    Ps3 keeps saying restoring database it stops at 40% and after like 1 minuite it goes to 100% then it does the same thing again by saying restoring data base.
    Hello
    Try a router reboot.
    1 power down ps3 and any pcs or laptops.
    2 Unplug all cables from router.Including power for 1 min.
    3 Plug all cables back in the router and power up.
    4 Try ps3 again.
    Another solution is some data on ps3 may be corrupt.You would need to do a restore of ps3.
    You will losse all info stored in ps3 such as username passwords and accout numbers.
    So write it all down if you can.
    1Turn off ps3 with switch in back.
    2 Turn back on,hold power button until you hear 3 beeps.
    3 go through setup until prompted to format.
    4 Then format.
    This operation can take as long as 1 to 3 hours.Also you will loose all info you put into ps3.
    Sep 22, 2011 | Sony Playstation 3 (PS3) Console
    My ps3 says "a serious
    This is one of the most serious PS3 errors you can get. You can try access the PS3 service menu and doing a restore.
    How to get access to service mode
    1. Make sure the PS3 is turned off,
    2. Press and hold the power button on the PS3 it will power on then power off.
    3. When it's off press and hold the power button again until you hear two consecutive beeps.
    4. It will ask for the controller to be connected via the USB cable,
    5. Turn on the controller and you will have access to the menu.
    Hope this helps.
    Feb 09, 2011 | Sony Playstation 3 (PS3) Console
    Try to sign in and error code 8071053D keeps appearing
    1. Turn the PS3 to standby power off.
    2. Turn off the power on the PS3 by using the power toggle switch on the back of the PS3 and unplug power cord.
    3. Restart your wireless router, if using one.
    4. Plug in the PS3 power cord and power on the PS3.
    5. Try creating a new connection on the PS3 by accessing the Network Settings menu option on the PlayStation 3.
    go for a minimum of 5 minutes in between each step to properly clear it
    i hope this helps you and please vote for me
    Dec 05, 2010 | Sony Playstation 3 (PS3) Console
    Hi, my ps3 shutting down when I turne on the power
    try rebuilding the database and the file system in recovery consol
    to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
    like on my 80g system it goes like this
    ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
    Oct 27, 2009 | Sony PS3 40GB Best Sellers Bundle Console
    Ps3 troubles
    The PS3 is essentially a computer....Light stays on because its a standby mode retaining power for ps3 memory etc.....
    Apr 19, 2009 | Sony Playstation 3 (PS3) Console
    Power Button
    just install your ps3 demos on system use webbrowser on ps3 to download demos or store the ps3 canot be shut down by power button on system itself only from controller or turning back off then on hope this helps
    Jan 09, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 power supply cost?
    nutterbutter
    In regards to looking for PS3 powersupplies you have 2 options. You can do a search through Ebay and/or you can do some searches on the Internet.
    I got one the other day for $35 after shipping.
    Here is some links that I ran a search on. Note PS3 is also a term used in computer powersupplies so you will get some hits on them as well.
    http://shop.ebay.com/items/ps3%20power%20supply?_dmd=1&_sop=12&tt_encode=raw&crlp=1652236613_9405&keyword=ps3+power+supply
    http://www.google.com/search?hl=en&q=ps3+power+supply&aq=4&oq=ps3+po
    Let me know if you have any more questions and/or problems.
    Issken
    Oct 01, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    73 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
