Question about Water Heaters
Boiler manual celsia F1 boiler manual
Ideal heating boiler f1 fault
Hi Janice, The link below is a short youtube video showing you how to fix error f1, Take care....CHEERS
https://www.youtube.com/watch?v=o9wpeIvPOb0
Mar 26, 2016 | Water Heaters
I've got a Worcester Bosch boiler had a leak In the pipe On the landing so a friend emptied the boiler an I fixed the pipe but I don't know how to refill the boiler
Can you get the manual online? You have the Manufacturer info so you probably have the model number too. I found a manual on Manuals.com for my boiler so they may have yours too which will hopefully have some information on filling boiler although I realize each installation is somewhat different but that's why it's difficult to answer you question. Usually there is a manual pressure valve that regulates the water pressure in the boiler which is usually pretty low...like less than 20 lbs. The manual should tell you the pressure as well. But this pressure valve has a flip handle that comes off the cold water line to the boiler to do just what you want to do...refill it with water. When refilling the boiler (if you find the valve, you may have to purge the air out of the lines which there is a whole other process for. But you shouldn't allow cold water into a hot boiler...it could crack it when the cold water hits the hot cast iron. So make sure the boiler is cool when filling it up.
Now go try to find that manual!
Nov 22, 2015 | Bosch Water Heaters
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
I have a Protherm 80e boiler which keeps going to the F1 mode
google your boiler it comes up with a manual go to page 26 it gives you 5 reasons why it goes to f1
Aug 16, 2017 | Water Heaters
Have protherm 100ec boiler british gas has replaced almost every part boiler will fire temp gauge rises to about 55 flame increase in strenght for about 10sec then boiler cuts out also they keep trying...
Any other symptoms? Is the fault apparent only when drawing hot water? Does the boiler re-light later? Alarm messages? F1? F3 for example?
It may well need a powerflush, but it's best to find out before spending big money with BG.....wish I could get away with charging that much for a flush!!!
FYV
Jan 27, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Boiler keeps going out
have you checked that you thermostat on wall is set to a reasonably high temp. if not when room eaches temp setting , then the boiler will switch off,. Other than this obvios one , i would suggest you could google your boiler for the manual /instruction.
Parts For Porsche Cayenne
Jun 11, 2012 | Reliance Water Heaters
Water Heaters Logo
389 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
