Question about Olympus FE-46 Digital Camera
My flash don't work at all when i turn it on a
My flash don't work at all when i turn it on a red flash sine flashs and i tried all settingsit still wont work can someone please help me
  • 85 Answers
1.if you can open and reset the connection of your strobe unit of flash unit inside.
2.the strobe unit or the capacitor of your flash need to replace.
3.need to rbing to service center
Posted on Jun 03, 2010
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
Red sercurity light flashes in my truck
You could try re locking the doors then unlock them. Then open the hood and disconnect the negative terminal on the battery for 2 minutes. Hook up the battery and start the truck. This will flush the PCM's cache and restore everything to its normal state.
Dec 11, 2011 | 1999 Dodge Durango
My turn signals don't work but the hazzards flash
if your hazzards flash, that means your bulbs will be good but, your turn signal fuse is blown. you should check that first, & don't forget to turn off your hazzards before you can see if your turn signals work again. give it a try.
Dec 01, 2011 | 2000 Dodge Caravan
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
Hi, I droped my SP-320 yesterday and now i can't turn it on. The red and green light is flashing. What does the flashing lights means? Joe
I have the same problem with flashing red and green light when I tried to turn on my Olympus SP-350.
I don't know what's wrong, so please let me know if you have any clue. I personally did not drop the cam, but someone else might and did not tell me :(
May 25, 2011 | Olympus SP-350 Digital Camera
I don"t know how to put my blue tooth in discoverable mode
Try this:
1. With your headset turned on, simultaneously
press the listen volume adjust button marked
+ (volume up) and the call control button.
Release the buttons when the indicator light
begins to flash red then blue.
2. While the headset is flashing red and blue,
use the phone menu to search for Bluetooth
devices and select "510 Plantronics".
3. When prompted for password, enter 0000.
The headset will flash blue when paired
successfully.
Don't forget to rate if this was helpful :-)
Sep 19, 2010 | Plantronics Explorer 230 Bluetooth Headset
Hi i have a 400w black and decker inverter as soon as i plug my lap top in to it the power light on the inverter flashs and it wont power my laptop
The output of this inverter (and most others) is a modified sine wave, which isn't quite the same as a true sine wave - like you get from a wall outlet. Unfortunately, most transformers (which is essentially what your laptop power-supply is) require a true sine-wave. Your inverter will work fine for many other 110V applications. You can buy an inverter with a true sine-wave output, but they are more expensive.
Aug 19, 2010 | Black & Decker Power Inverter PI400AB
Toshiba 1360 copier has a red flashing 8 with arrows or zigzags can any one tell me what this means. the copier does not work while in this mode
When that is flashing your copier is jammed or thinks it is jammed, check the paper path for any sines of paper.
Jun 12, 2010 | Toshiba 1360 Black and White Copier
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
Olympus FE-46 Digital Camera Logo
138 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
