Question about Ariete Cafe Retro Espresso Machine
Do i need to take apart the machine to replace the gasket
  • 69 Answers
The gasket you mean is the one upper to the filter I suppose...bring to service if the gasquet is not well inserted can cause a lost of pressure or even explosion!
Posted on Jun 01, 2014
The handle is coming apart. It does not fit tight enough & sometimes falls while the coffee is brewing. Where can I purchase a new one to fit my Solis SL 70 machine purchased late in 2004.
HI
If the portafilter is coming out when brewing your brew head gasket needs to be replaced. If you have never replaced your brew head gasket its way beyond time. They should last about 3-4 years at the most. With a good brew head gasket the portafilter should be easy to lock in, not requireing a lot of pressure to force it over. Try replaceing the gasket first before you invest in a new portafilter. If you really need one I have some and the gaskets.
Jan 31, 2011 | Solis Portafilter for SL Series - 521.05
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
There is water in the oil. I don't know if it is a blown head gasket or blown head
You can't tell untill you get it apart. and then some times you still can't see a crack. It needs to go to a machine shop to be checked. I send them all out to be checked when I do a head gasket replacement.
Nov 27, 2010 | 1998 Ford Escort
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Replacing orange gasket in top or portafilter
here is a picf920683.png of the portafilter for the saeco
May 09, 2009 | Saeco VIA Venezia
Replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
How hard is it to replace a head gasket on an '04 Hyundai Elantra
depands on how mechanical your are . and you will need to send the head to a machine shop for plaining.you need tools and a torque wrench and the specs for tighten the head back down .it can be done with patience and on rare cases you can lift the head to replace the gasket without taking everything apart
Feb 27, 2009 | 2004 Hyundai Elantra
Ariete Cafe Retro Espresso Machine Logo
77 people viewed this question
Top Ariete Coffee Makers & Espresso Machines Experts
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Ariete Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
