Question about Harman Multimedia Harman Kardon Guide+Play GPS500 Car GPS Receiver
What do i do to get the back cover off of my gps off.
What do i do to get the back cover off of my gps. i took all 4 screws out and it wont come off
    Problem Solver:
  • 16 Answers
Ok first its a sealed unit if you crack it open bye bye warranty take it back to get them to have a look you dont know what your doing
Posted on Jun 03, 2010
Rand mcnally tnd 510 wont
No you don't have to cut into it. Might be to late now but this is how you take it apart. 710 is the same way
1- Remove the front film. This is held on with 3m double sided tape. So it will be stiff and you will have to work at it for a little while.
2- Once the front cover is off you will see the retaining bezel under this. There are about 8-12 screws running around the outside of this. All of these screws must come out. Don't lose them since you will need them to put the unit back together again.
3- Once you have all these screws out a small flat screwdriver can be worked under the edge to begin separating the retaining cover from the unit. Patience and time are your friends. Impatience means new unit.
4- Once you remove the retainer you will have access to the insides of the unit. Reassembly is the reverse order
Oct 16, 2013 | Rand Mcnally TND 710 GPS Receiver
TomTom 0ne
There are 4 screws:
1. Remove front bezel
2. unscrew 4 small screws (1 hole has anti tamper tape over)
3. remove "dome" rear of unit.
4. Remove 2 screws holding speaker in
5. Carefully remove all metal tape covering electronics
6. Remove 4 small screws securing PCB to unit
7. Remove 2 screws holding black plastic battery clip
8. Unplug small battery connector from PCB board.
9. remove battery and insert new one
Nov 09, 2007 | Tomtom ONE GPS Receiver
Cant get subwoffer apart took out 2 screws and moved lach other side still wont come off Help???
After you swivel the center latch, press down on the two plastic latches on either end (in the same crack) with a flat head screwdriver. Make sure you remove the knobs used to adjust the base and LFE levels. Now you can push the plastic cover back about a 1/4 inch and then lift it off (I used a flat head screw drive to pop it off - took some effort). Inside, remove the 2 phillips screws from the top of the green circuit board, unplug the board, and push the 4 plastic holders out of the way so you can flip the board over. Replace the 3 amp, 250 volt fuse.
I haven't tried putting mine back together again yet. I'm off to Radio Shack...
Dec 20, 2010 | Bose Acoustimass 15 System
Where do you replace the battery on the gps ,sony nv-u44 model.I took the 4 screws out in the back,but could not pull it apart.help if you know the quickest way to change the battery.It won't charge with...
The connecor to the battery is under the circuit board. You must remove the circuit board.Just remove the 4 screws and unclip the battery. Reverse the process for installation.
Jul 20, 2010 | Sony NV-U44 GPS Receiver
My cd player wont play cds
take the panel off 4 screws or so just on cd player & over heater control . remove cd player , cover screw's , wire harness ... cd 's probably stuck . remove all cd's put everything back together install cd's again . took me 6month's to figure out my girlfriend did in less than hour with wout breaking a nail!!!!!! lol gd luck .
Apr 28, 2010 | 2004 Nissan Titan
How do I remove the battery from TomTom One XL in order to replace it?
just remove the 4 screws on the back of the case and split the front and the back halves. becareful when removing the back cover as the battey and speaker are attached to the back cover and the wires are connected to the main board (front half)
the battery is attached to the back cover with two sided tape.
bill
Oct 31, 2009 | Tomtom One XL GPS Receiver
Touch screen stop working
Omnitech GPS systems are very decent for me. I have 2.
There were several reports of GPS problems beginning on or about 11-14 June 2009. This is due to the GPS navigation messages rollover from 255 to 0. Some GPS systems fail to accommodate this behavior; Omnitech is one of them.
Staples did provide a firmware update a few days later. There are also other firmware updates available on the net. I personally successfully update the firmware and resolve the problem around June 15, 2009.
Otherwise, the problem should go away after 1-2 weeks.
thsquare
Jul 12, 2009 | Nextar Q3 GPS Receiver
Daewoo DP-4100P
I removed the outer casing - 4 Screws. 1 at each side near the front and 2 in the back of the unit.
Then removed DVD top cover - 4 Screws, there are only 4 screws holding the cover down. (carefull not to drop them inside the rcorder).
Then lited out the DVD.
Took no mre than 10-mins.
Terry Pearson
Apr 12, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Garmin iQue 3600 GPS Receiver
There are 4 torx screws in the back, they need to be taken off and then the case unsnaps, and wala you have it apart.
Jul 11, 2008 | Garmin iQue 3600 GPS Receiver
Harman Multimedia Harman Kardon Guide+Play GPS500 Car GPS Receiver Logo
85 people viewed this question
Top Harman Multimedia GPS Experts
Are you a Harman Multimedia GPS Expert? Answer questions, earn points and help others
