We recently had to update our Comcast Cable Service and received 2 update kits that required our setting up the ditital remote for our 2 TV sets. One was a Sharp and the set-up went without a hitch. The TV in our bedroom is a GoldStar. When I tried each of the 4 different set up codes given; none worked. I went to Comcast for a new remote, thinking the remote might be the problem. The second attempt with a different remote was no more successful. Comcast said the some manufactures may have more possible set up codes than are shown on the sheet and that I should contact GoldStar. The 4 set up codes listed are: 10178, 10030, 10002 and 10019. There is also a process on the instruction sheet that is designed to assist you if your code may not be listed. I tried that to no avail. Are there any additional set up codes other than the 4 listed above? Thanks greatly for your assistance.
  • 11,800 Answers
GoldStar is the old (really old, like from 15 years ago) name of LG which means that your tv is also very old. New remotes are loaded with the codes for the newest brands and models first, the few remaining memory is filled with what they think will work best with their particular remote. Unfortunately since none of their few codes are working on your tv and nothing you can do will fix that (that remote isn't programmable) you will have to continue using the old remote, nothing else to do.
Posted on Jun 03, 2010
How do I program a Toshiba remote to a zenith converter box
Signal converter boxes are pretty easy to set up - ABC News
abcnews.go.com/Technology/AheadoftheCurve/story?id=5485537
Digital Switch: How to Set Up Your Converter Box. ... If you subscribe to cable, satellite or some other pay-TV service, you'll continue to receive programming. ... aToshiba TV in my kitchen: Magnavox's TB100MW9 and Zenith's DTT901. The boxes are simple enough to set up, though I prefer the Zenith's remote control and ...
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!
Zenith remote control code list - channel recovery morning ...
www.thompsontv.com/zcodes.html
Dec 15, 2015 | Zenith Televison & Video
Xfinity remote setup
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 03, 2014 | Comcast XFINITY
When i turned on my Samsung LED television all i get is a blank grey screen with no sound. i have Comcast but my other tvs are fine. i can play a dvd on it with sound and screen, no problem and the menu...
Follow the cable from the Comcast set top box and see where it is plugged into the tv. Check what that jack is labled and then select that option on the TV menu. My guess is that the tv and dvd are not both on component 2, if the are then the set top box is not connected directly to the tv but to the DVD unit. In that case, if the cable set top box is connected to the dvd, then you might need to put the tv on ch 3 (or maybe 2 or 4) or you may need to switch a setting on the DVD box or remote that selects the TV/DVD option.
Dec 05, 2013 | Samsung Televison & Video
How do I set my comcast cable remote to the Kenwood cs 5.1 receiver?
These codes may work:
Depending on the comcast model remote you have: Some require the full 5 digit code while others only use the last four digits.
Codes for Kenwood receivers:
31313 31571 30027 31007
Most Direct, Comcast and COX remotes use the same basic codes either with or without the first digit which is always a 0,1, 2, or 3. (0 for cable boxes, 1 for TVs, 2 for DVDs, 3 for audio amps and receivers)
Hope this helps.
Jun 05, 2011 | Kenwood VR-507 Receiver
How to connect tv to comcast cable box
If you only have the comcast receiver and a TV, take the input (wire from outside the house or outlet on wall) and screw that onto the input of the comcast receiver. Take another wire (or RCA, component connecters or whatever means the box and TV provides) and go from the output of comcast receiver to the input of the TV. Set the TV input mode (on the TV itself or by the remote) to whatever mode you hooked up the cables to (video 1, aux, video 2, etc) and you should see a picture. From there use the comcast remote to change channel. If you use the round cable (rg56 or rg59) you will not need any other connections between the TV and the box. The video and audio are broadcast on the same line. If you use RCA (yellow red white) connectors, yellow is video, white and red are audio) you will need all three wires from comcast receiver to TV. I hope this helps and good luck!
Nov 18, 2009 | Audio Players & Recorders
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
We recently purchase 2 TB1 10MW9 DTV Digital Analog Converters to connect to 2 of our Ananlog TV's. Our TV reception is from Comcast Cable & we had then set-up our Main TV with their converter. Our...
U have paid cable, u don't need the converter box.Not even the analog tv require the coverter box, if u have paid cable or satalite tv or telicom signal.All ur tvs is hook up to the Comcast Cable correct?That all u need not, require the converter box.
Sep 03, 2009 | Televison & Video
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Mar 01, 2009 | RCA RCR450 Remote Control
Comcast remote/Onkyo AV Receiver
I have this exact same problem. Anyone know how to fix this?
Dec 22, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
