Question about Ironman 430r Recumbent Bike
Ironman 420r Recumbent Bike Power Supply
What is Wattage, voltage, and amperage of the power supply for the Ironman 420r Recumbent Bike
3 Suggested Answers
SOURCE: where can I find and AC/DC adaptor for ironman 430
Found mine; rating is 9V DC 1000mA
Posted on Mar 21, 2010
SOURCE: error message on recumbent bike
The problem might be the gearbox. I know because I have the same problem.  Keys fitness is out of business, but "The Treadmill Doctor" has purchased the inventory of parts for the bikes. They will help you troubleshoot, and have parts available if you need them. The number is 1-888-340-0482. Or, you can go to treadmilldoctor.com.
Posted on Apr 03, 2009
What is the output voltage, amperage, watts and polarity for Schwinn 203 recumbent bike? I have a pile of transformers and don't know which one my mother-in-law used. Thanks for all replies.
If the recumbent digital computer gives you an option of power supply or batteries then you can deduce voltage of the power supply by counting the number of batteries needed times 1.5 (1.5 volts = voltage of AA or AAA battery).
You can deduce typical current by multiplying the number of batteries by: AA = .05 amps or AAA = .01 amps.
Your next issue will be to deduce the polarity. Look at the Schwinn to look for a symbol that will show you polarity. Typically the center of the plug is: + positive and the outer shell is - negative. There are instances where those two are reversed.
If this is all too confusing then Google the recumbent model number to find replacement power supplies ($35 to $45 US).
Nov 28, 2014 | Schwinn Cycling
Power cord for a 420r
Contact the manufacturer they will have a website and will supply the correct cable for your unit. make a note of the units model number and or serial number. This is usually found on a sticker
Apr 23, 2014 | Ironman 430r Recumbent Bike
Battery charger for 3800 RC
This link will take you to the product you are needing. The technology inside the power supply allows it to adjust to the voltage required to charge the battery on the 3800RC.
Power Supply Kit with Plastic Output Connector Domestic Stairmaster...
Jan 12, 2014 | Stairmaster 3800RC Recumbent Exercise Bike
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
My computer turns off automatically with light on keyboard and motherboard
HP Compaq dx2300 Desktop PC?
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=3352967&lang=en&cc=us
90 percent of desktop computer failure, cab be attributed to;
A) The computer is dirty inside, to include the Power Supply.
B) The Power Supply is bad
Suggest you start with cleaning the inside of the computer out, but suspect the real problem is the Power Supply.
Why?
Because the CD-ROM is not working.
Primer:
Your Power Supply converts your household/business AC electricity, into 3 low main DC Voltages.
Depending on your country;
USA = 120 Volts AC
Europe = 220 Volts AC
Australia = 220 Volts AC
Japan = 100 Volts AC
This is converted into 3 low DC Voltages for the computer;
A) 3.3 Volts (DC)
B) 5 Volts (DC)
C) 12 Volts DC
Each of the above is a voltage power rail.
The amperage for each power rail is stated on a label, on the Power Supply.
Voltage times Amperage = Wattage
Again, Voltage x Amperage = Wattage
All of the amperage of the voltage power rails are combined, (Added together), to equal the maximum Wattage, the Power Supply will deliver.
This should be stated on the Power Supply label also.
A) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power.
[ Intel Pentium Dual Core E2160? Can use up to 65 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29 ]
You press the Power On button. This in turn presses against a Power On switch,
http://www.directron.com/atxswitch.html
This in turn, activates the Soft Power On feature of the Power Supply, and turns it on.
The first chipset to receive power is the BIOS chipset.
The BIOS program looks to see what devices are connected, does a Ram Memory count, turns the Processor on, then hands the computer over to the Operating System.
[ Windows XP and Windows 7, are two examples of an O/S ]
Primer over.
Your Power Supply provides enough power to turn the Processor on, then falls to it's knees. Doesn't have enough power to keep the Processor on.
[ A typical CD/DVD drive requires 15 Watts of power. It isn't there when all of the other hardware needs power first ]
Suggest you find a Power Supply that is KNOWN to be good, and COMPATIBLE, for a test unit.
Or you can test the 3 main voltage's coming out of the Power Supply, with a Multimeter set to DC Voltage.
Or you can just replace the Power Supply.
I would prefer you test with another unit, or test the voltages, before you spend your hard earned money.
It's up to you.
Diagnose the problem first. I could be wrong with the above, but if you diagnose using a test unit, or test the voltages, we will know whether the Power Supply is the problem.
Always start with the power First.
Perhaps there is an unused computer you may have access to, and can borrow it's Power Supply for a test unit. Has to be KNOWN to be good, and has to be COMPATIBLE.
What is Compatible? Means it has to have at least the minimum power cables, and the Power Supply must fit in the computer case.
(It is an ATX power supply)
Need recommendations for a Power Supply, post in a Comment.
Also will step by step guide you in replacing.
Regards,
joecoolvette
May 20, 2012 | HP Compaq dx2300 Microtower - RT950UTABA...
Amperages not working
Check the voltages of a 4 pin connector with a multimeter.
The 5 volt will be on the red and black wires.
The 12 volts will be on the yellow and black wires.
If the voltages are not present or wrong then the power supply is faulty and needs to be replaced.
When you replace the switch mode power supply, make sure the total wattage of the new power supply is equal to or greater than the old power supply.
May 19, 2011 | Computers & Internet
The power supply of computer can run the car amplifier?
probably not if it is high wattage amplifier
PC power supplies dont have enough amperage to run an amplifier
it is 12 volts but only a few amps
voltage is like turing on water in your sink amperage is like how hard you turn the water on you wont have enough 'flow' from a PC powersupply - sorry
good idea though!
if it is very low power amplifier you might be able to get it running
try it worst thing that will happen is that the fuse in the power supply will blow
Mar 24, 2011 | Car Audio & Video
What is the total wattage of the power supply
This information is usually printed on the label of the power supply.
Jan 05, 2011 | Computers & Internet
Supply voltage issue...
the x1650 card requires extra amperage, not extra voltage. It runs on the same 12 volts as the rest of the computer. The issue is that if you have an underpowered power supply, of if you have a lot of other devices hooked up, you may need a better power supply to provide enough wattage to the card. As long as you have at least a 400w power supply, I would expect you to be alright.
Feb 13, 2008 | ATI RADEON X1650 Graphic Card
Ironman 430r Recumbent Bike Logo
482 people viewed this question
Top Ironman Sport & Outdoor - Others Experts
Are you an Ironman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
