Question about Akai Televison & Video
My akai pt46dl10 tv has no power will not turn on have switched to other outlets still the same
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Turn off the TV and unplug the cord after five minute from the power socket. Let it sitting without power for about 10 minutes and plug the power cord back into the power socket. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the TV and if the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour to drain off current from all components especially capacitors before performing any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
  • kryptonite98 Jun 03, 2010
    How do i get to the power supply? is it protected or just behind the panel?
  • Rylee Smith
    Rylee Smith Jun 03, 2010
    It is located behind the panel, it is the board where the power cords/plugs goes into. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Tv will not come no timer lite blinks
Things You'll Need:
  • Electrical outlet
  • Fuses
  1. Check that the power cord is securely plugged into the power outlet.
  2. Make sure that the power outlet is receiving electricity by plugging a different device into the plug and turning the power on. If the other device does not work you likely have a blown fuse or tripped circuit breaker.
  3. Replace the blown fuse or reset the circuit breaker as needed. If it happens again, an electrician should assess the problem.
  4. Contact akai Support if Steps 1 to 3 do not solve your problem. Only a trained service technician should attempt to fix the power problem with your television
Jan 22, 2011 | Akai PT46DL10 46" HDTV-Ready Television
My Akai Tv won't turn on at all
hello do you mean no power, if so have you checked the fuse in the plug if ok then it's possible that the glass fuse inside the tv may have blown this will be in the power supply
regards
shaun
Oct 08, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Need to find a bulb and cage for Akai pt46dl10
If your serial# has J P/N DR150E23
If it has a Z in serial# P/N L920-0017/P306
Mats Electronics 1-800-628-1118
And Go to E-Bay look under Electronics/type in Lamp number.
Feb 18, 2010 | Akai PT46DL10 46" HDTV-Ready Television
We had a power outage, while the tv was on. Now
have the same TV. Sounds like a power supply problem. www.nodevice.com has the service manual for your TV. Get the model number off the TV, goto service manual at nodevice.com. I got the manual and it was around 10 dollars canadian. well worth the 10 dollars too!
Jun 05, 2009 | Akai PT46DL10 46" HDTV-Ready Television
I need a remote for model # pt46dl10 akai tv lcd 46 in
have same tv searched and tryed alot of universal ones that where supposed to work but did not finnaly found out only logitec harmony 550 universal remote works bought on on craigslist for 65 candian and works perfect with this model
May 05, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
My akai dlp tv is flashing power and lamp the red lights then to the timer is also flashing green light
the back cover is not on the TV correctly. on the back cover there is a safety switch so that the lamp light is not exposed. The lamp emits radiation and UV rays. Not healthy.
Dec 23, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Akai pt46dl10
I actually have the service manual but i will just post your answer
10. Reset the lamp timer by entering the sequence 90918988 on the Remote Control keypad when
running operational software.
Oct 17, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Televison & Video Logo
27 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
