Can the solar monkey be used charge a ipod touch. We have lost the instruction manual and are having some problems
  • 185 Answers
Yes it can actually you can get the information right here there is a PDF and the specs. where it specifies that it can be used with an ipod as long as you have the adapter.
if it works for you, don't forget to rate me
thx
Posted on Jun 03, 2010
Tip
How to reset a frozen ipod click wheel and touch
To reset any frozen iPod with a click wheel, you will first want to ensure that the hold button is not on or stuck by sliding it to the on position and then off again.
Next you will need to simultaneously press and hold both the menu and center buttons for at least six seconds but until the apple icon appears on the screen.
If this does not resolve the issue, the next best resolution is to plug the iPod into a wall charger and let it charge for several hours or until fully charged.
Then repeat the reset process.
To reset an iPod touch, you will need to press and hold the Sleep/Wake button and the Home button at the same time for at least six seconds or until the Apple icon appears.
As will the iPod click wheel models, if the first attempt does not work I would suggest charging the unit for several hours or until fully charged. After words, repeat the reset process.
If a reset does not resolve the issue, the next trouble shooting step would be to restore the iPod using the latest version of iTunes.
To restore an iPod touch, open iTunes on your computer and connect iPod touch to your computer with the provided USB cable. After a moment or two you will notice that in the left column under Devices, you will be able to see an iPod icon; click on your iPod touch, then click on Restore in the Summary tab. Follow any on screen instructions and do not remove the iPod until after it is completely restored.
To restore an iPod click wheel, open iTunes on your computer and connect iPod touch to your computer with the provided USB cable. After a moment or two you will notice that in the left column under Devices, you will see an iPod icon; click on your iPod. In the resulting page you will see a button that says restore. Click that and follow any and all on screen instruction ensuring that you do not disconnect your iPod until it is completely restored.
WARNING: If you do not have a back up of your data on the iPod you will have to re-gather it. I always recommend making a back up of your iPods content before an issue arises to ensure that there will be no lost data.
on Dec 29, 2009 | Audio Players & Recorders
How to use ipod
There should be some instructions in the User Manual. If you have lost it, then there are ones available at the Apple website. Good Luck!
Jul 08, 2010 | Apple iPod touch
I lost instructions on setting the timer.
I Googled in Diehl digital timer and located a website that had the exact timer I have. Included in the list of information was a manual with instructions on setting the timer. I downloaded the instructions and set the timer. Exactly what I needed.
Jan 17, 2010 | Solar Digital Electronic Timer 20/40/60...
Bose ipod dock shows it is charging ipod and ipod shows to be playing but no sound. Any solutions?
Which ipod are you using? a great many docks are not compatible with the touch. When shopping for a dock to use with the touch there is a separate icon on the packaging that denotes ipod touch and iphone compatibility. If you no longer have the box or user's manual check with Bose' customer service.
If your ipod is not a touch I would check to be sure that the dock connector is clean and clear of debris.
I am also assuming that the ipod synchronizes normally with your computer (meaning that the ipod's socket is good) Try listening to the ipod via headphones while it is connected and charging to make sure that there is not an internal problem with the ipod.
I hope this helps.
Jul 17, 2009 | Bose SoundDock digital music system...
Can't download songs from my pc to my 3rd gen nano ipod
I had the same problem with my ipod touch. I soon realized itunes is too protected with their software. So i googled around and i found an Itunes alternative called Media Monkey. I absolutely love it. You could also use Winamp too which i als found good.
Apr 09, 2009 | Apple iPod touch
How do i transfer purchased napster tunes to my new ipod?
download media monkey and see if u can import music and use it thru their
Apr 01, 2009 | Apple iPod touch
Lost manual - it won't turn on
Do you still have your USB cable to connect it to a PC? Or power adapter to connect it to the wall?
If not, you can probably find one on EBay or some other such site.
It probably just needs to be charged. If you can get a USB cable for it, it will charge from most PCs without the need to install any software.
Mar 19, 2009 | Apple iPod touch
Ipod Touch 8gb problems
Hi K,
Ahhh, everything has suddenly become very clear :) All is well and there is nothing wrong with your ipod. Heres what you need to do.
  • First, install the very latest version of iTunes onto your PC or Mac - Download it from http://www.apple.com/itunes/download/
    Tip: Uncheck the two boxes and don't enter your email address
  • Once that's installed, start iTunes up and connect your iPod to the computer via a USB2 port (any on a laptop but not through a hub; on a PC tower use only one of the USB ports on the rear of the machine, ie, none of the ports on the front) - It's gonna need charging (That's what the Batt symbol is showing) so leave it for a good 2hrs.
  • While it's charging I'd recommend spending some time familiarizing yourself with the user guide - it explains alot of these symbols and more importantly how to get started with your new iPod. You can download the manual from here: http://support.apple.com/manuals/#ipodtouch
  • When it's good and charged then follow the onscreen instructions for the iPod on iTunes. You have to register the iPod first before you can use it. So once you've done this all will be well in the world for you. See page 5 and 6 of the manual.
All the best
Sean
PiDigital
Dec 27, 2008 | Apple iPod touch
Ipodshuffle
I hope you didn't purchase itunes because it's a free program.
Download it from here:
Dec 30, 2007 | Apple iPod shuffle Second Gen. Silver (1...
138 people viewed this question
 Grubhead
Grubhead
