Question about MTX Terminator TN400/4 Car Audio Amplifier
Mtx terminator 250 stop workind and red light is on
    Guru:
  • 403 Answers
Check the ground make sure its not loose from the frame of your car thats why the red light comes on.
Posted on Jun 03, 2010
How do I wire my 12inch mtx ts 55 subwoofer two outlets red with red and black with black or red and black and red and black
The TS55 is a DVC subwoofer that can be wired for either 4 ohms (voice coils in series) or 1 ohm (voice coils in parallel). The appropriate wiring depends on the amp.
If the amp is stable at 1 ohm, wire both positives and both negatives to the matching amp output terminal (parallel) as shown in Wiring Option #1.
If the amp isn't stable at 1 ohm, connect a jumper between the positive on one voice coil and the negative on the other voice coil. Then connect the remaining positive and negative to the matching amp output terminal (series) as shown in Wiring Option #2.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3
Jun 17, 2011 | MTX TS551022 Car Speaker
I just replaced my old terminator 12" subs with two new 12" jl audio w3 4ohm subs and the mtx terminator amp keeps shutting off and flashing red. I kept everthing the same from my original mtx...
You may have touching speaker leads going into the amp. Make sure the tinsel is not touching across the speaker inputs on the amp. Also check your ground. It should be solidly connected to the vehicle chassis in a paint-free location. Finally, make sure there are no exposed speaker wires touching the vehicle chassis.
Mar 09, 2011 | MTX Terminator TN400/4 Car Audio Amplifier
My amp i just instaled is a terminater mtx 250 watt amp and the lights are flashing instead of a constant red i checked my power and ground what else would it be
Check your remote wire on both the deck and amp... If the remote wire is loose it will turn the amp on and off constantly... Also check to make sure that the fuses on the amp it self are properly seated.
Oct 30, 2010 | MTX Car Audio & Video
I bought a MTX Terminator amp and the light is red when I turn it on, but it works. Red usually means protect mode but it works fine. Should the light be red or green?
all depends on that amp... if there was an issue it wouldnt work, and the light would be by a protect symbol... if its just red next to the power symbol i say no issue.
Feb 18, 2010 | Car Audio & Video
My light on my amp is red i think it is sopost to be green
that means that your amp is in protection mode, check all your wires and also the speaker configuration.
Jul 15, 2009 | MTX Terminator TN400/4 Car Audio Amplifier
Burned out
mtx goto mtx.comthey should send u sam call costumer service they will email it 2 u
May 05, 2009 | Car Audio & Video
Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
May 01, 2009 | MTX Terminator TN400/4 Car Audio Amplifier
Apx stopped working, MTX 702x
maybe the audio amplifiers Ic´s damaged or the power fet
Mar 06, 2009 | MTX X Thunder 702X Car Audio Amplifier
My amp doesn't turn on...
If there is a zero ohm connection across the B+ and ground terminals, it should blow the fuse as soon as you apply power.
Oct 10, 2007 | MTX Thunder TA7801 Car Audio Amplifier
MTX Terminator TN400/4 Car Audio Amplifier Logo
647 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
