Question about Puzzle Massey Ferguson Tractor
My 492 tractor makes a high pitch noise like somthing is slipping arounf where the fan pully's are.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
I am not totally familiar with this model MF but I do own four of them. The noise you hear sounds like you are about to loose a water pump. If you can get your hand in there with the engine off, see it the fan blades will wobble when try to move them forward and backward, not round and round.
You alternator is up there also and could be loosing a bearing. My bet is the water pump though.
Posted on Jun 29, 2010
Heater/air conditioning blower fan makes high pitch noise
Above the passenger's feet, 3 bolts to loosen and it comes right out...
Jun 05, 2013 | 1994 Mercury Capri
Renault scenic Auxiliary belt tensioner making high pitched noise
Time to replace the pulley, you can test it by pulling off the belt and spinning the pully with your hand or some compressed air, if it makes noise then its time to replace.
Nov 05, 2012 | Cars & Trucks
What would cause whistling noise near pully and belt area noise gets louder with acceleration
The engine serpentine belt may be worn or wet. The belt slips, causing a high pitched squealing or whistle noise. The other possiblility is a bearing beginning to go out on one of your belt driven components
Mar 27, 2012 | 1999 Pontiac Montana
My laptop makes a high pitched noise
The high pitched noise you hear is most likely caused by the CPU cooling fan on your laptop. If you suspect that this high pitched sound is caused by the fan going out, you can spray your laptop with compressed air to get the dust off of the fan.
This solution will make your laptop work at a cooler temperature, and reduce the noise.
If the problem persists, seek a certified laptop repair specialist.
May 22, 2011 | Computers & Internet
91 S-10 it has a high pitch scream
It sounds like a worn or loose fan belt. It's slipping on the pulleys causing the screeching noise.
Nov 22, 2009 | 1991 Chevrolet S-10
Fan noise upon starting.
It could be the belts that are slipping on initial start-up. When the belts are cold, they will slip if the belt(s) are loose. It could also be the tensionoer pully. This is not normal for any vehicle under any circumstances. Good Luck Jim
Sep 09, 2009 | 2004 Land Rover Discovery
High pitched noise
Then you will need to stop the fan and see if the noise is still there. If yes then its in the compressor. If it goes away then replace the fan
Sep 08, 2009 | GE Refrigerators
I have a high pitched noise which appears to be coming from front right engine compartment (as you are looking at the engine) which sounds kind of like a belt that is squealing. It is intermittent. Just...
Could be several things. WHICH ENGINE?.. 4 cylinder (has three belts, power steering/water pump, alternator & A/C compressor, one tensioner pully A/C compressor), The V6 2.7 (has only one belt, 1 Idler pully and 1 tensioner pully), the V6 3.5 has two belts - A/C/alternator, and power steering - there are two tensioner pullys). Noises can be caused by the belt(s) themselves, pullys, bearings, pully bearings, water pump shaft bearings (or belts/pullys rubbing up against something). Let's not forget that there is also belt(s) behind the Timing Belt cover as well as pullys and bearings associated with the timing system. You could start by removing one accy drive belt at a time (alternator, water pump, compressor, power steering, etc) to see whether or not the noise goes away in each case. If after each case, you discover the noise is still there, it's probably behind the timing belt cover (idler/tensioner pully, water pump shaft bearing, crankshaft bearing, etc.). Good Luck
Jun 29, 2009 | 2004 Hyundai Santa Fe
Loud high pitched noise from belt
When you have the belt off, spin that idler pulley and see if it turns easily or makes noise. Check if the bearing feels good and smooth or if it wobbles any. While you are at it, check the fan and fan clutch to see if they turn smoothly also. There should be some resistance to the fan clutch, and make sure the fan isn't rubbing on anything.
Replacing the idler pulley is usually done as a unit since the bearing is part of the pulley.
May 07, 2009 | 1991 Ford F250
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Puzzle Massey Ferguson Tractor Logo
155 people viewed this question
Top Puzzle Toys Experts
Nikki  Mclean
Nikki Mclean
Gary Nitowski
Lesley Cameron
Lesley Cameron
Are you a Puzzle Toy Expert? Answer questions, earn points and help others
