Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice buildup on bottom of freezer?
Ice is 3inches thick, runs out freezer door.
  • Kenmore Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from FreezerIce buildup on bottom of freezer? - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 04, 2010
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Freezer not cooling properly. Temperature alarm went off. Turned off now.
Look inside freezer on the rear wall to look to see if there is frost buildup. If yes then unplug and manually defrost defrost for about 3 hours if you only open freezer or place hot water in a bucket and place inside freezer and close the door. Let me know by answering my post here, Thanks John T.Appliance 911
Contact
click below for parts breakdown
I have a feeling the problem could be 1 of three things=> WR9X520 Defrost Timer, WR51X465 Defrost Heater or the WR50X0131Defrost Thermostat
May 28, 2015 | Viking Professional VCBB363 Bottom Freezer...
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
How to stop ice building up in freezer
Ice buildup is generally caused when you have a leaky door seal. Make sure that the door seal is intact and the door is properly closed. Another cause could be that the tube to the ice maker has detached. Hope this helps
Dec 06, 2014 | Refrigerators
How do I stop frost/ice from building up in freezer (bottom freezer of French Door Stainless Steel bought in Dec 2011)
Check the door gasket carefully for cracks or other leaks. It is crucial to have a good barrier between the moist room air and the super-dry air inside the box that will quickly suck in the ambient humidity and form frost.
It would be difficult to change the sensor and the heater, and if the defrost cycle is running (and you feel some warmth around the bottom of the box when it is cycling) then the sensor and heater assembly are working and do not need to be replaced. The best practice is to remove any frost buildup at regular intervals and often to prevent a thick buildup that is difficult to remove.
Nov 19, 2014 | Samsung RF26VAB (25.5 cu. ft.)...
Ice build up on freezer door
your door gasket isnt set right call for warranty service
Jun 03, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Our kenmore refrigerator/freezer went warm. We
It could be one of several problems -
1) Failed compressor relay
2) Failed compressor
3) Failed component in the defrost system
4) Bad door gaskets
5) Failed door light switch
Questions to answer -
1) Was the compressor (large black domed item with three tubes (one stubbed) at the bottom back of the frig.) warm or hot?
2) Was the condenser fan running?
3) Was there thick ice buildup inside the louvers of the back wall of the freezer?
4) Was the fan running inside the freezer?
5) Look up my "Tips and Tricks" article on testing your door gaskets.
6) Open the door slightly and look inside as best you can. Is the light on or off? Continue to open the door until you see the light go on to confirm the light switch is working.
Your response will give us an idea where to look to find the problem.
Dec 13, 2009 | Cars & Trucks
Everything in the freeze has a thick layer of ice
Typically, this is an indication that the seal on the door needs to be either cleaner or replaced. begin by cleaning it thoroughly, also clean the frame of the door. Then defrost the ice using a blow dryer and dry it. Then over the next few days you will know if it is the seal if the ice forms again.
Dec 05, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
My bottom freezer door isn't aligned right the
Don't think buildup is the problem. Sometimes the doors become loose and need adjustment.1a4bfab.gif See if you can locate the model serial number so I can help you better, Sea Breeze
Mar 27, 2009 | Maytag MFF2557HE Bottom Freezer French...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
99 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
