Question about GE Nautilus 24" Built-in Dishwasher
Dish washer just doent start to wash when i turn it to start?
It makes 'regular' noise as i turn dial. I have check the fuse pannel and it is fine.
any suggestions would be great help
thanks
  • 70 Answers
Pls check 1)water is filled in the tank. 2)check wash pump jammed.if any bearing is failur this will persist.
Posted on Jun 03, 2010
Hav3460aww
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
Apr 28, 2014 | Maytag HAV3460AWW Top Load Washer
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
It doesnt spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 26, 2010 | KitchenAid KAWS700L Top Load Washer
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
Washer will not start at all. I checked electric plug and is hot with 120 volts. Hot and cold water connections are okay and water is on. Washer worked fine right before - two loads were washed, would not...
fit new plug top if that does not work remove top and check mains filter. if you cannot do this your self phone your local engineer and ask how much he wants to fix it . should only be about £50.00
Feb 11, 2010 | Washing Machines
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
Feb 27, 2008 | Maytag LSE7806A Top Load Stacked...
Washer problems
How old is the washer? Some washers you can pop the top on if so check your power cord as it enters the washer. There may be a loose or burnt wire at the terminal block. Some washers won't start if the lid switch isn't making. Check that also.
Dec 11, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE Nautilus 24" Built-in Dishwasher Logo
565 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
