Question about Electric eZip Mountain Trailz 26 Men's Mountain Bike
I need my repair where do i go
My breaks need doing
  • 66 Answers
Visit your local bike shop or check the yellow pages
Posted on Jun 08, 2010
Headlights dim when I step on the break.
Check ground wire(s) or other wires for corrosion, broken, breaking, also clean and repair as needed.
Other than that consult the technician or refer to repair manual.
Jan 24, 2014 | Cars & Trucks
I have to push the break peddle all the way to the flood and it's still hard to stop do I need break fluid or break pads??or something else? Please help ford taurus
I would start by checking brake fluid. However if it's that low, it's leaking somewhere and should be repaired. If the pads are due, you'll hear a squeel or if there really bad grinding.
Jul 05, 2013 | Cars & Trucks
Break light is on as well as abs. Repair shop says they do not have access to the code to repair. Breaks work fine per two different shops. Is it just a switch that needs repair.
one of the sensors on the ABS system could be shorted, have the OBD codes read,, then cleared, that will help you see or limit what to check, once the codes have been cleared,, the lights should go off, if they come back on, then you need to locate the problem with the abs
Sep 06, 2011 | Ford Expedition Cars & Trucks
Toyota lucida under normal breaking the breakes seem ok, if i pump the breaks while slowing down they stop working any ideas
Firstly, why are you pumping the brakes to slow down. If its because the brakes are not efficient, then they need to be checked and repaired. Secondly, it will reduce the braking efficiency to near enough nil, if you are pumping the brakes, doing that, exhausts the vacuum pressure that gives the brakes assistance.
Feb 10, 2010 | Toyota Previa Cars & Trucks
HOW DO i REPLACE A CV AXLE ON A 1999 OLDS ALERO
first of all you will need a 1/2 break bar and a 35mm metric socket.besure to buy the socket that you use to remove front axle nut.any other socket may break.you will need a hub bearing puller.and a haynes repair manual.
Dec 20, 2009 | 1999 Oldsmobile Alero
How do i repair left front hub & bearing assembly on a 2000 ford taurus v6 24v dohc
BEST TO GET A HAYNES REPAIR MANUAL IT HAS PHOTOS AND INSTRUCTIONS ON HOW TO REMOVE HUB BEARING ASSEMBLY.YOU WILL NEED A 1/2 SIZE TORQUE WRENCH FOR HUB RETAINING NUT.ITS TORQUE IS 170 - 202 FT LBS.MAKE SURE YOUR TORQUE WRENCH MAXIMUM RANGE IS AT LEAST OVER 200 FT LBS TORQUE.YOU WILL ALSO NEED A AXLE NUT SOCKET.ITS A BLACK SOCKET LIKE IMPACT SOCKET.ITS GRADE 8 STEEL.YOU HAVE TO USE THIS TYPE.A REGULAR SOCKET WILL BREAK.WHEN REMOVING AXLE NUT.ITS ON TIGHT.YOU WILL ALSO NEED A 1/2 BREAK BAR TO BREAK IT A LOOSE.ALSO REMOVE WHEEL COVER.WITH CAR WEIGHT ON WHEEL YOU HAVE TO LOOSEN AXLE NUT A LITTLE.NOT ALL THE WAY UNTIL YOU GET CAR OFF GROUND.WORK SAFE BECAREFUL.
Oct 28, 2009 | 2000 Ford Taurus
Canon s5 is battery cover will not open
Unfortunately there is only two solutions for your problem:
1. Gently but firm, press the battery cover lid down and at the same timemove the button to open it, and at the same time, slide to the side the battery cover.
Try it as much as times are needed.
2. If still is stuck, then you will need to disassembly it, or pay at a repair service for it.
If is stuck, and force to open it with a tool (pry tool or similar), you have the risk of break the slide plastic channels in the camera body, or break the battery cover, or break a switch located in the mainboard that senses when the camera door is closed, or everything at the same time, making worst the problem and causing you to spend more on repairing it.
Of course that if it has warranty, I do recommend you to make it valid prior to try in send it to repair.
If is out of warranty, Canon charges $120.00 for any repair (or so), so you will need to find a cheaper repair shop for it.
Best regards,
Jul 19, 2009 | Canon PowerShot S5 IS Digital Camera
How do you do a rear break job on this car.
you have to pull the wheel then loose the break for you to pull your break drum, then you will see the break pad already.
May 01, 2009 | Chrysler Voyager Cars & Trucks
Electric eZip Mountain Trailz 26 Men's  Mountain Bike Logo
85 people viewed this question
Top Electric Cycling Experts
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
