Question about Metrologic Instruments MS7120 ORBIT Barcode Scanner
SCANNER FREEZES UP
POST PRODUCTION STUBS AND PAYMENTS SCANNER FREEEZES UP IN RED LIGHT MODE WHEN IT FEELS LIKE IT. SWITCHED FROM USB PORT POWER TO DIRECT POWER FROM WALL SOCKET AS THEY SAID THE DRAW ON THE COMPUTER MAY BE TOO MUCH , BUT PROBLEM PERSISTS
    Guru:
  • 285 Answers
Update its drivers
Posted on Jun 03, 2010
My canner ls4278 is making a sound and turnin red when i scan
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
Jun 10, 2014 | Symbol LS 4278 Barcode Scanner
Red flashing power light
I am sure the original poster will have probably replaced the unit by now but I just had a similar problem with my Epson Perfection 2480 Photo scanner so I think it is still worth posting the solution in case other people hit this problem in the future.
All I had to do was put the switch underneath the scanner to the "unlocked" position and then reboot the unit.
Hey presto it burst back into life.
It's annoying to see that the manual seems to suggest that the red light means the unit is "dead" !
Feb 24, 2014 | Epson Perfection Office Equipment &...
Red light keeps flashing
Install the most recent driver: http://graphics.kodak.com/docimaging/us/en/support_center/index.htm
Ensure the scanner is NOT plugged in to a USB 3 port (usually blue or has the letters "SS" (Super Speed)). If so, turn off, plug in to a USB 2, power it back up with the most current drivers.
Dec 05, 2013 | Kodak ScanMate i1120 Flatbed Scanner
Sandisk mp3 freezes
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 04, 2010 | SanDisk Sansa e200 MP3 Player
Unable to import text file to access table
Hey everyone, I was able to fix my problem using the following:
filnam = Me![Text2]
Set objFile = CreateObject("Scripting.FileSystemObject")
Set objText = objFile.OpenTextFile(filnam)
Set rs = CurrentDb.OpenRecordset("FlatFileImport")
once = False
If Not IsNull(Me.Text2) Then filnam = Me.Text2
Open filnam For Binary As #1
Do While Not objText.AtEndOfStream
strTextLine = objText.Readline
Data = Split(strTextLine, ",")
If once Then
rs.AddNew
rs.Fields(1) = Data(0) 'Site ID
rs.Fields(2) = Data(1) 'Client ID
rs.Fields(3) = Data(2) 'Client Name
rs.Fields(4) = Data(3) 'DDA Account
rs.Fields(5) = Data(4) 'Process Date
rs.Fields(6) = Data(5) 'Good Checks Singles
rs.Fields(7) = Data(6) 'Good Checks Stubs
rs.Fields(8) = Data(7) 'Good Checks Partial
rs.Fields(9) = Data(8) 'Good Stubs Partial
rs.Fields(10) = Data(9) 'Good Checks Multi
rs.Fields(11) = Data(10) 'Good Stubs Multi
rs.Fields(12) = Data(11) 'Check Only Checks
rs.Fields(13) = Data(12) 'Check Only Stubs
rs.Fields(14) = Data(13) 'Check And List Stubs
rs.Fields(15) = Data(14) 'Check And List Checks
rs.Fields(16) = Data(15) 'Suspense Checks
rs.Fields(17) = Data(16) 'Suspense Stubs
rs.Fields(18) = Data(17) 'Correspondence
rs.Fields(19) = Data(18) 'Envelopes
rs.Fields(20) = Data(19) 'Express Mail
rs.Fields(21) = Data(20) 'Lookup Stubs
rs.Fields(22) = Data(21) 'Online Lookups
rs.Fields(23) = Data(22) 'Stubs Only
rs.Fields(24) = Data(23) 'StopFile Hits
rs.Fields(25) = Data(24) 'SLC
rs.Fields(26) = Data(25) 'SL2
rs.Fields(27) = Data(26) 'MICR Scanline
rs.Fields(28) = Data(27) 'KeyStrokes Correspondence
rs.Fields(29) = Data(28) 'Keystrokes SLC
rs.Fields(30) = Data(29) 'Keystrokes SL2
rs.Fields(39) = Data(38) 'Exception Queue
rs.Fields(40) = Data(39) 'COA Queue
'IMAGE ARCHIVE ITEMS
rs.Fields(41) = Data(40) 'Image Archive Reports
rs.Fields(42) = Data(41) 'Image Archive Storage
'BATCHES PROCESSED
rs.Fields(43) = Data(42) 'Batches Processed
'ARC ITEMS
rs.Fields(44) = Data(43) 'Low Speed ARC Attempts
rs.Fields(45) = Data(44) 'High Speed ARC Attempts
rs.Fields(46) = Data(45) 'Low Speed ARC Converted
rs.Fields(47) = Data(46) 'High Speed ARC Converted
'ICL ITEMS
rs.Fields(48) = Data(47) 'ICL Attempts
rs.Fields(49) = Data(48) 'ICL Converted
rs.Fields(50) = Data(49) 'ICL Non-Conforming images
'RETURN ITEMS
rs.Fields(51) = Data(50) 'Auto Returns
rs.Fields(52) = Data(51) 'Returned Items
'POSITIVE POST (CDM) ITEMS
rs.Fields(53) = Data(52) 'Positive Post Checks
rs.Fields(54) = Data(53) 'Positive Post Stubs
'REMOTE PAYMENT CAPTURE ITEMS
rs.Fields(55) = Data(54) 'Remote Payment Single Checks
rs.Fields(56) = Data(55) 'Remote Payment Single Stubs
rs.Fields(57) = Data(56) 'Remote Payment Multi Checks
rs.Fields(58) = Data(57) 'Remote Payment Multi Stubs
rs.Fields(59) = Data(58) 'Remote Payment Check Only Checks
rs.Fields(60) = Data(59) 'Remote Payment Check Only Stubs
rs.Fields(61) = Data(60) 'Remote Payment Check & List Checks
rs.Fields(62) = Data(61) 'Remote Payment Check & List Stubs
'DOLLAR DEPOSTIED & PP CORRO REJECT ITEMS
rs.Fields(71) = Data(70) 'Dollars Deposited
rs.Fields(72) = Data(71) 'PP Corro Rejects
rs.Update
End If
once = True
MyLine = ""
MyLine = MyLine & ch
MyLocation = Loc(1)
Loop
MsgBox " File has been successfully imported! "
Close #1 ' Close file.
rs.Close
'close and erase the file from memory
objText.Close
Set objText = Nothing
Set rs = Nothing
Sep 08, 2009 | Microsoft Access 2003 for PC
AT&T Tilt Smart Phone usb drivers license scanner
Well I'm sure there is barcode scanner application. Try SPB Software, Handango.
May 30, 2009 | Cell Phones
My wireless mouse freezes
I had a similar freezing problem with a wireless Logitech mouse and also a problem with the wireless keyboard, sometimes keystrokes would not register and sometimes they'd repeat a dozen times.
I was not able to fix the problem, so I got a Microsoft wireless mouse and keyboard, hoping it was a driver conflict that wouldn't affect both products. Wrong. The exact same thing happened to the Microsoft mouse and keyboard.
The cause of the problem turned out be that I had the receiver plugged into a USB hub along with several other devices. Moving the receiver to one of the USB ports in the back of the PC fixed the problem.
Apparently these wireless desktop devices don't like sharing USB resources with anything else.
Apr 17, 2009 | Microsoft Wireless Optical Mouse USB...
My usb port light doesn't turn green
first check the usb driver is installed & usb in enabled in device manager
Dec 26, 2008 | Dynex 7-Port USB 2.0 Hub
Pc does not recognize 4490
HI-
Try to replace the usb cable and try to plug it in a different USB port on your computer. Hope it didnt break aything when it fell, try to check the ports from the scanner as well. make sure you are not getting any red light when scanner is turned on. check under device manager for conflicts under imaging devices. If you see a question mark or if the scanner is not listed unde imaging devices, keep me posted so that we can check on your unit. Thanks!!
Jun 18, 2008 | Epson Perfection 4490 Office Flatbed...
Overheating
We had a GE 7 port usb port and it overheated and melted----thank goodness I got up when I did or the house would have caught on fire. The only thing we had connected to the usb port was a APC battery backup unit. Any reason why the usb port overheated?
It was pugged into the battery backup unit and I am hesitant to rehook the computer up to the battery backup unit and also will not by another GE usb hub again and whatever hub we do use, I will not plug it into an outlet!
the computer was downstairs and I noticed the odor of electrical burning smell upstairs---the unit was bought nov 25, 2007 and we returned it to BJ'S for a refund today-----I do not reccomend this product to anyone.
Oct 29, 2007 | GE JASCO (HO97878) 4-Port USB Hub
Metrologic Instruments MS7120 ORBIT Barcode Scanner Logo
224 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
William Robinson
William Robinson
Sandeep Kumar
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
