Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawn tractor forward movement problem
My 15 year old Craftsman model 917.252590 with auto transmission moves extremely slow when advancing the speed lever forward. The tractors forward movement will stall out & stop unless the speed control lever is pulled back to neutral & them moved slightly forward. The drive belt was replaced about 18 months ago & is good condition. The Kohler engine is fine, the tractor just will not pull.
  • Anonymous Mar 14, 2014
    Lever under seat doesn't go all the way forward. Tractor doesn't move when I move transmission lever
  • 420 Answers
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Posted on Jun 04, 2010
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
The mower moves slow in all speeds what is the problem
If the engine is running well you either have a loose drive belt or the transmission is on its last legs.
Aug 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I adjust the speed control handle
Well on my AYP manufactured tractor, which is much like yours but has the name Husqvarna on it, the hydrostatic transmission is shot and it exhibits much the same characteristic. That is no forward nor reverse movement until it gets nearly to the end of its range. The F/R lever on the right side is connected to a much smaller lever on the end of a shaft which goes into the transmission. What I would do is check the linkage to make sure that the range of travel on the speed control moves the smaller lever input into the transmission. If the range of travel is the same, you may need a new transmission, they are expensive. If there is some slop in the linkage, you may have another day in the sun. You can google "manual, craftsman, lawn tractor" and find some links to get a manual. What I did was find another lawn tractor as the cost of repair far exceeded the value of the old mower.
Jul 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn tractor model 917.270821 ( Auto trans)
Check the fluid level in the transmission. If the fluid level is low, the trans will act as if it's slipping.
Nov 25, 2009 | Vacuums
The transmission will not engage,
it is possible that there are no parts missing - reach in and push the "rod end over the rear axle doesn't move the lever" lever forward - the brake is sticking in the "on"position - wiggle the lever back and forth, if it moves more than 1/4 inch, use a half inch wrench to tighten the nut holding the lever until the lever has only about 1/4 inch movement
Jun 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Mar 30, 2009 | Craftsman Garden
Both forward and reverse speed are decreasing
Hi, check the main drive belt, the belt is stretched out. you need too replace the main drive belt.
If this doesn’t work for you, please write back. Thanks,
Nov 23, 2008 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
649 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
