Question about Compaq Presario 5000 PC Desktop
I got this error when installing XP on my old Presario 5000
I got this error when installing XP on my old machine. XP partitioned, formated, and copied the files. After rebooting I got this message...
NTLDR: couldn't open drive,multi(0)disk( 0)rdisk(0)partition(1)
    Guru:
  • 285 Answers
Ur installer disk is not proper
Posted on Jun 03, 2010
Good evening, I have a compaq presario 5000 which had windows ME installed I want to upgrade it to windows xp pro I completely swiped the entire os deleted the partition and created a new one in order to...
Hi elizabeth,
It seems that you are selecting the quick format option when installing Windows XP.
Try running the XP setup again and choose the option to format the hard drive with the NTFS option, but use the standard option & NOT the "quick" option.
Let me know if this solves the problem.
Best wishes,
Graeme
Jan 16, 2011 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 i tried to install XP Sp1 or Sp2 but doesnt work. after format the hdd and copying the files the pc reboots as usual and an error appears NTLDR: couldn't...
Make sure you cd with OS is clean and not damaged since this will some times cause issues.This error usually means you computer is not seeing hard drive for some reason.. the partition is not getting on it probably because of bad sectors. i rare situations it will be because of mother board since i have had the same problem. first make sure your hard drive is set as master under pin selection. most times cable select is ok but it might not work always even that it was not changed. make sure ide or sata cable is firmly in or better just remove it and put it back in snug. when you do format do a regular and not quick even that you have done it already since this will attempt to fix bad HD sectors. if this does not work try another hard drive or try this one on another machine if you have one. Hope this helps.
Aug 09, 2010 | Computers & Internet
I installed system mechanic professional and hit the drive scrubber button and wiped out my hard drive completely. i tried to install widows vista and i it won't allow it to install. i get a file error...
In that case it affects the file system of your hard drive that's why it fails the windows vista installation. In order to fix it you need to delete the partition of your hard drive and create a new one using a partition manager software.
If you can connect your hard drive into another computer you can perform a disk partition using the Disk Management (In Windows XP: Control Panel > Administrative Tools > Computer Management > Storage > Disk Management)
To help you with the procedure on "How to use Disk Management."
http://support.microsoft.com/kb/309000
Using Disk Management, after creating a partition in your drive, proceed to formatting.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
Error installing XP after Vista
When you boot from your XP Installation CD, make sure you delete the primary partition, recreate it, then format C: with NTFS.
Dec 14, 2009 | HP Compaq Presario C700T
Unable to reinstall OS for Compaq Presario 5000.
Use ontrack disk manager
select advance installation
make partitions own do you want
after the completion process
take reboot
now install operating system that you like
even 98 or XP.
It will work 100% guaranteed.
Thank You
Aug 09, 2009 | Compaq Presario 5000 PC Desktop
Windows xp installation problem
You might need to use the "Floppy" version of the Driver upon install (if you know what the chipsets are. Most likely it's Intel and you can slip stream the driver files into a new XP CD.
However if a partition is formated from Vista and you attempt to install XP over it without formatting it, crash is almost certain - XP and Vista have different versions of NTFS.
If you want both XP and Vista on the same machine, ALWAYS install the older one first! i.e. XP first. And create only 1 partition in XP where you intend to install on.
Then install Vista afterwards with Vista created partition.
May 23, 2009 | EliteGroup RC410L/800-M2 (V1.0)...
Partition and format
u need win xp bootable disk for it.
Apr 22, 2009 | Compaq Presario 5000 PC Desktop
Compaq restore cd
Hi mithz.
I'm not you people.
(Please keep track of the user who you ask a question too).
When you installed windows 2000, (If you formatted the entire drive during install), you might have taken out the small partition that holds data for a system restore. No version of windows likes
you going backwards. In order for you're system restore CD's to work you'll need to format the hard disk drive. Windows will not install if Windows 2000 is found on the drive. The fastest way to get Windows 2000 off the drive without deleting any other partitions Compaq installed would be to go to the hard disk drives manufacture's site & download their setup tools/utilities. You'll be able to creat a bootable floppy disk that will function in a dos-like mode out side of windows. You'll be able to format the Windows 2000 partition. Once that is done you will be able to incert the restore CD (s) & install Compaqs windows XP.
You may need to pull the drive in order to see who made the drive. EX; Seagate, Smsung, Maxtor ect. Here is the link for Seagate. http://www.seagate.com/www/en-us/support/downloads/seatools
Every manufacture has similar bootable floppy software.
Read the instruction provided by the manufacture on how to create the floppy disk & how to run it.
Good Luck!
Mike
Jul 15, 2008 | Compaq Presario 5000 PC Desktop
About hard disk
I am assuming you got this error while trying to install Windows XP. If so, The solution to this problem will result in the LOSS OF ALL DATA ON YOUR HARD DRIVE. This is a two part process.
1) Check to make sure hard drive is seated in laptop well.
   Enter BIOS and ensure that your hard drive is detected. If not, try the auto detect feature that most BIOS' have and see if this detects your hard drive. If not, try restoring the BIOS defaults and see if that works. If not, hard drive may be bad.
   Continue to part 2.
2) Insert your Windows XP CD and boot computer from the CD and wait for setup to load.
  • At the Setup Notification screen, press Enter to continue.
  • At the "Welcome to Setup" screen, hit Enter to continue.
  • Read the Windows XP Licensing Agreement and press F8 to agree.
  • On the Xp Setup screen, you'll create an installation partition, but first some housekeeping. If you have any existing partitions you must delete all of them before proceeding.  After deleting all partitions, select "Unpartitioned space" and pressing Enter. And then press Enter again to confirm the partition size as is (it should already be set to the maximum size).
  • Next, select "Format the partition using the NTFS file system" and press Enter. Xp will now install.
If the same error appears then the hard drive is probably bad.
Oct 24, 2007 | Compaq Presario 5000 PC Desktop
Restoring OS on presario 5000 series
you need to format the whole hard drive as it's the hidden restore partition that is giving you problems, but you may not be able to format it using the XP cd or restore disk. You may have to use the old FDISK as this may be the only way to restore the hidden partition. You will need a boot disk, see below link for win98 as this is what you will need to fdisk, then follow instructions on bottom link, as it's too long to type in here. http://www.bootdisk.com/ http://www.pcanswers.co.uk/tutorials/default.asp?siteid=8§iontypeid=7&subsectionid=606&pagetypeid=2&articleid=6046&page=2
Sep 24, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
