Question about Acer Computers & Internet
LED of My Notebook has broken - Acer Computers & Internet
  • 2,427 Answers
U mean the LCD screen ????
ok look at the screen you will notice some rubber stoppers,, pry them off to reveal screws,, unscrew them to take the lid off..
now u will notice the screen mounted to the case,, remove the screws holding the screen,, lift the screen off and unjack the wires,, now you can unjack it,,
order a new one from the manufacturer or a local repair shop.. and reverse the above procedure to reinstall it.. now a similar brand with the same screen may work,, just once it jacks in thats all u need,,
Posted on Jun 03, 2010
Toshiba P205d-S7454 powers on but has amber battery light and the touchpad data port is broken off motherboard will till post ?
it will still post if your motherboard, led display, hardisk and memory is working? try used usb mouse if your touchpad is broken!!!
May 01, 2014 | IBM ThinkPad T40 2373 Notebook
Broken lcd loptop
Can replace with 14.0 LED Screen.
We have following LED in stock
http://laptopsmumbai.com/laptop-repairs/
Feb 21, 2013 | Lenovo G460 14" i5-480M 2.66GHz 4GB 500GB...
When you turn the laptop on it turns off with 30 - 60 secs.
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Acer Aspire 5735 Notebook
Dell 910 mini will not recognise any battery and will not recharge
You may have a loose DC jack:
Jan 23, 2011 | Dell Inspiron Mini 10 Notebook
Broken LED
If its a broken LED you need to call LENOVO HARDWARE SUPPORT to replace the LCD
1 877 453 6686 option 2.thanks
Jan 06, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
Unit will not power on// has a solid amber light// turns green for about 3 seconds then back to amber
You may have a bad DC connector:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 17, 2010 | IBM ThinkPad T20 2647 Notebook
Asus f80 can't start. when connect to power adapter no activity on notebook, no power led etc. led on power adapter ok.
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 21, 2010 | ASUS F80Q-X2AM Notebook
No power LED
did you test if there's any voltage?
Mar 10, 2009 | Dell Latitude D530 Notebook
No screen light on switching
there are two possibilities
1. you might not properly insert your hardware
2. its broken
resiting it will help
if not replacing it will do
Jan 17, 2008 | Sony VAIO VGN-S150 Notebook
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
