Question about Toro Electric Trimmer
I have a 13" Toro model 51358 trimmer and it constanly has no string showing. I have to remove the cap and pull more out through the feed hole. Why?
  • Al Kupchella
    Al Kupchella Jun 03, 2010
    There is supposed to be a metal grommet surrounding the hole. Is there a metal grommet or is it just a plastic hole?
  • dliedm Jun 03, 2010
    No metal grommet, just an elongated slot.
  • 708 Answers
The bumper on the bottom is worn out or the sprin inside it is broken. You should be able to tap it on the ground and string come out.
Posted on Jun 03, 2010
Toro 8" 12 volt trimmer.
Look at this tip, an oldie but a goodie:
http://www.fixya.com/support/r2827867-winding_line_trimmers
Should be what you need.
Best regards, --W/D--
Jun 03, 2011 | Toro 13" Corded Trimmer - 51358
Gettin spool off to change string
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
May 29, 2011 | Toro& Electric String Trimmer
I cannot get more line out of my toro 15" electric trimmer. It cannot be empty, it has only been used once. The cutting line will not extend out any more. Should it not?
Sometimes the line can become fused together.remove the spindle and manually pull the line. Replace and the tap and feed should work fine.
May 12, 2011 | Toro& Electric String Trimmer
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Toro Electric Trimmer Logo
255 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
