Question about Cobra 29 NW CB Radio
Cobra NW LTD CB radio
Have a almost new CB w/ new coax and antana..Set swr but red tx light still comes on indicating problem with transmitt..Others cannot hear me. If I continue to key up on mic,may "blow out" radio.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Get a good antenna from Radio Shack or www.copperelectronics.com. Test your SWR it should be 1.5 or less. That light in the radio just indicates a problem(but sometimes there is no problem--Someone has messed with the insides and adjust it wrong(misalignment). Ground to metal frame good. Change coax+ends. Sometimes end soldering is bad.
Posted on Nov 06, 2011
    Problem Solver:
  • 6 Answers
Start out by getting a good antenna like a wilson or k-40 if your using it on a big rig make sure its a metal mirror and door a lot of big rigs use fiberglass and thats a nono you must get a no ground plane antenna...its all in the antenna...good luck doc's cb shop ny
Posted on Aug 19, 2008
I have a cobra 29 ltd the red antenna light was coming on replaced the coax with 18' coax have Wilson 2000 antenna calibrated radio red light still coming on and and swrs not staying consistent when...
Best way to locate the problem is connect the radio to a Dummy load known to be good====if swr still comes on it is in the radio--if not in the antenna system.
Apr 28, 2012 | Cobra Radio Communications
Cannot recieve all the time
You will need an SWR meter to check your antenna. FIRST.
I would find help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the swr. only if you need a part or something ..
I don't charge to SET SWR"s .. only if the cust needs a insulating washer or another antenna, or new coax, so-239 etc... I would be glad to help you.. let me know if we can -- CB Shop Temple, TX
Nov 26, 2011 | Cobra 29 LTD CB Radio
How to match a antenna to a cobra 29 LTD Classic
You are actually tuning the antenna to the vehicle it is mounted on here are some very good resources. http://www.rightchannelradios.com/pages/cb-antenna-tuning-guide-pv-c0-61.htmlhttp://www.wilsonantenna.com/swr.php
Be aware that if your radio has been modified it may produce a dirt signal that an swr meter may read as reflected power. In this case it may be more accurate set with a unmodified radio also if your radio is setup for a linear it may have a deadkey to low for the swr meter to calibrate correctly.
Hope this was of help.
How to match a cobra 29 ltd classic to its antena
When i key in both green lights turn red. is this normal ?
One of the lights is marked RX/TX. This light normally turns red when you press the mike key. The other light indicates a bad SWR if internal circuits are properly aligned. If someone has turned the pot which sets the level at which the light comes on, it may come on when you press the mike key. Check your SWR with an external meter to see if you have problems in the antenna system. The way I set this light in my shop is to put a 150 ohm resistor on the antenna connector and set the control so that the ANT light just comes on.
Jun 15, 2011 | Cobra 29 LTD CB Radio
I disconnected and reconnected the cobra 29 nw ltd classic and now my voice is heard very low and slow it was working fine just before disconnection. can you help
How did you disconnect it?? Antenna wire?? Power supply?? Microphone?? May be that you have a short in your coax in back of radio. Try taking it loose and screw it back in. Try new coax. Turn up Mic gain knob or change microphone. Make sure power wires are connected RED to RED(+) and Black to Black(-). Try grounding radio to metal ; if inside house ground to metal water pipes, filing cabinet, breaker box or meter box or 8 foot rod into earth. Measure SWR it should read 1.1 to 1.5. Measure power supply with Voltmeter it should be 12 to 15 volts. Check antenna plug in back of radio is my guess or microphone itself.
May 09, 2011 | Cobra 29 LTD CB Radio
The radio does not transmitt but I can here other radios
CHECK SWR's, and check for loose coax connectors and try a different microphone. new stock mic's $6.99 max price here in temple, TX, and rk56 noise cancelling mics$38.99 Max here too Temple, TX.
Feb 13, 2011 | Cobra 29 LTD CB Radio
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
Cobra 29 NW LTD Classic wont calibrate and red antenna light keeps coming on
The calibrate knob only calibrates the radios SWR meter, the owners manual will show you the procedure for that. If your ANT light is coming on, it is telling you that your SWR is to high, and may cause damage to the radio from reflected power. You should purchase an in line meter as the radios internal meter may be somewhat unreliable. You need to tune the antenna to the lowest SWR possible. Typically anything under 2.0:1 is acceptable. Radio Shack sells a meter for about $50, and is pretty accurate. Antenna mounting can also cause high reflection if it is to close to other objects. Google "CB antenna tuning" or read the instruction manual for you antenna, and you should be able to figure out how to properly tune the antenna.
Jul 07, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
144 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
