Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox WorkCentre C2424N
We used to be able to scan and copy from our 5 workstations to this machine. But now the machine menu has this error message- 39,014.40:202560. We can print to the machine, but no longer can we copy. Can you tell me what the error code indicates and how I might fix it?
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If reseating the document feeder cable doesn't solve this problem, you may have to replace the document feeder. Here's a video that shows you how. Good luck">
Posted on Feb 14, 2011
  • 2,072 Answers
That is an issue with the scanner or document feeder. Turn the machine off, Disconnect the conenctors from the back of the feeder and also the one on the right side of the machine, next to the power cord.
Reconnect the cords, make sure in particular that one by the power cord is screwed in tightly, it is a nuiscence to tighten the bottom screw, but that bottom screw is probably not tight enough as it and is causing your fault.
Power the machine back up and see if that eliminates the problem.
I not please let me know.
Posted on Apr 09, 2008
Im receiving an error message 03-340 on my Xerox WorkCentre 5632 how do I fix this
Network Controller start up error. Switch the machine OFF and ON, using the On/Off button at the side of your machine. otherwise change card.
Jan 06, 2015 | Xerox Office Equipment & Supplies
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
Upon booting I get this error, A fault has Occurred. Some features may not be available. No error code to go on...Xerox Workcentre M24 Now were not able to select any functions on the touchpad, and we...
Sounds to me like you need a drum or one of the other routine maintenance items.
The way to find out is to press your machine status button, then look under supplies. You will probably find that a drum life has expired, the IBT cleaning roll or fuser life have expired.
I am sure if you look there one of those "supply" items has reached its end of life.
In the same area under the machine status , there is also a section there for active messages and fault codes. Make sure you look there. If you have additional questions please ask.
If there is an active message or fault code, e-mail me at Just put Xerox M24 in the subject line please.
Feb 24, 2010 | Xerox WorkCentre M-24 Color Copier
I am using a Xerox WorkCentre M15i connected to a server via a USB cable. I am trying to configure the scanner so that each user can perform a scan from the workstations without accessing the server...
There is a device called a Pocket Pro that attaches to the machine and you can then hook it via a RJ45 connection. I believe Troy makes that device. I have used it several times with success. Its basically a print server device.
Feb 02, 2010 | Xerox WorkCentre M15i Laser Printer
How to open a message???help!!!!!
On the console you should find menu buttons. Find jobs or job prints. Select your number job and print it.
The menu buttons have many features you can scroll through. The print reports can print out the menu of the different menus of the fax machne.
good luck.
Feb 17, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Xerox Workcentre Pro16fx - H4 error code after power outtage
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Feb 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Error message on Xerox workcentre 7242, error 010-333
Fuser jam, maybe the exit switch ?
If you turn the unit off and back on does it come up ready to copy or ready to scan you job
Jul 07, 2008 | Xerox Office Equipment & Supplies
Currently working on XEROX WorkCentre Pro 55. Want to scan documents to my computer from newwork printer. What do I need to set up in order to utilize this feature. I tried scanning to a programed user...
> Support & Drivers > WorkCentre Pro 55 Support > Search Results Solution: Set up Network Scanning Using Server Message Block (SMB) Filing With CentreWare Network Scanning Software v 5.5x bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Prerequisites:
  • The printer must be connected to the network.
  • The IP Address of the printer is required, and the HTTP option must be enabled on the printer. If you do not know the IP Address, or whether HTTP is enabled, print a Configuration Report. See the Related Items below for additional information. If you do not have this information or the printer is not configured correctly, contact your System Administrator for assistance.
  • A user account for the scanner to login to the scan server must be created (account needs full control access rights). The user needs to be a local user on the workstation and not a domain user.
    NOTE: SMB uses local rights and not domain rights. Record the username and password for future use.
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
  • CentreWare 5.5x must be installed on a Microsoft Windows server or workstation on the network.
From the workstation or server where CentreWare is installed:
  1. Click on [Start], point to [Programs], select [Xerox CentreWare], and then select [Add Network Scanner]. The Add Network Scanner Wizard window will be displayed.
  2. Click on the [Enable a new Xerox System Scanner for network scanning and associate it with a scan server] radio button, and then click [Next].
  3. Select [Specific IP Address] from the Find Devices pull-down menu and continue with step 4, or select [Specific TCP/IP Hostname] and skip to step 5.
  4. If Specific IP Address is selected, an IP Address field will be displayed. Enter the IP Address of the printer in the field, click [Next], and then skip to step 7.
  5. If Specific TCP/IP Hostname is selected, a Hostname field will be displayed. Enter the printer’s TCP/IP hostname in the field, and then click [Next].
    NOTE: Select Specific TCP/IP Hostname if the Printer is using DHCP to resolve the IP Address and has a Hostname assigned.
  6. If the printer has been configured for Scan to File, a window will be displayed with a 'This device has already been configured for network scanning. Continuing will overwrite its current configuration. Do you want to continue?' message. Click on [Yes].
  7. The Enter Password window will be displayed. Enter your system password in the field provided, and then click [OK]. The Server Type (Filing Protocol) window will be displayed.
    NOTE: The initial system password at machine install is 1111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  8. From the Server Type (Filing Protocol) pull-down menu, select [Windows (SMB)].
  9. Click on the [Browse] button located below the Location (\\Server\ShareName\Path) field. The Choose Location – Windows (SMB) window will be displayed.
  10. Browse to the server and then to the Scan folder where the CentreWare scanning folders will be installed, and click [OK]. The Location field will be displayed with the scan server name and the path to the shared scan folder.
  11. Click [Next]. The Xerox System Login Name window will be displayed.
  12. Enter the scan user name and password (this is the user account the printer will use to login to the server share) in the fields provided, and then click [Next]. The Distribution Server window will be displayed.
  13. Do not make any changes. Click [Next].
  14. Click on [Manage User Templates]. The Manage User Templates window will be displayed.
  15. Click on [Modify Template List] to begin selecting template users for this scan server installation. The Modify Template List window will be displayed.
  16. Make a selection from the list of Users and Groups, and then click on [Add] to create a scan folder and template for the selected user or all members of a selected group. If necessary, repeat this step to add additional users or groups.
  17. When you have finished, click [OK] twice. The Finish window will be displayed.
  18. Click on [Finish] to upload the scan settings to the printer. The Add Network Scanner Wizard window will close when the settings have been uploaded.
Jun 02, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
