Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Have misplaced manual for our Kenmore Freezer Model # 25321741106 Water is leaking to floor. Need to empty tray and defrost, but need advice. There was ice under bottom basket that we have removed. Still ice frozen behind wall. Help!!
    President:
  • 1,469 Answers
Hi, the manual for the model of the freezer is not available even on the internet.
How will give you some links to guide you through on what to do consigning the leaks in the freezer.
ehow.com/how_4695980_fix-leaking-refrigerator-bottomdrawer-freezer.html.
or
servicemagic.com/article.show.How-to-Fix-a-Leaking-Refrigerator.14123.html.
or
ehow.com/video_112132_fix-leaking-refrigerator.html.
Hope it helped.
Take care.
Posted on Jun 03, 2010
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
May 22, 2017 | Kenmore 13.7 cu. ft. / 388 liter Upright...
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Kenmore chest freezer - why is there a 1/2 inch of ice in bottom
Hello. If your freezer is not a self defroster, you must have had a power failure for a few hours that caused a melt with water ending up on the floor of the freezer and then refreezing. IF you have a self-defrost model, your defrost cycle produces some water which should make it's way down to the evaporator tray just above the floor... in your case, the small hole in the floor is plugged and the water is accumulating on the floor rather than making it's way to the evaporator tray. The fix is to clean the evaporator tray, defrost the ice with a blow dryer, locate the hole and clean it out with a couple of pipe cleaners or cotton swabs. Regards, Joe
PS please rate my answer. thank you.
Jan 28, 2010 | Freezers
Manual defrost
On my upright freezer I use pans or trays I have and set them in the bottom where it catches nearly all the water. I don't have to empty them till it's all melted because it till hold all of it.
Sep 06, 2009 | Fisher Scientific Freezer Isotemp* Plus...
I have a Kenmore upright freezer-model LFFH2067DW2 -the red light has been on for at least 12 hours and the freezer is defrosting-water is leaking on the floor-there is a vent insidethe freezer and the...
I was made aware of your concern and would like to offer a few ideas you may want to consider. Water dripping down is not a leak during defrost condition as this would be the ice melting. Normally, there would be a drain hose specifically to channel the melted ice/water to a drainage system. The amount of water would then be proportional to the amount of ice melting as with the length of time to completely melt, drain away.
Perhaps you could check the filter/drain screen as well as the drain opening for any blockage/clogging. You could also try checking the same on the drain hose as well as for possible kinks. Additionally, there would be a sensor behind a boxy cover that triggers the system back into operation. If there is still melted ice/water inside the freezer, then the sensor would prevent the unit from turning on completely. You may want to check this sensor and verify that it is dry.
An exploded parts diagram would help you identify/locate the above mentioned parts.
Good luck and thank you for using FixYa.
Feb 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer Defrosting
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Aug 05, 2008 | Freezers
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
109 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
