Question about HP Photosmart C6180 All-In-One InkJet Printer
Paper feed causing jam a part relating to this has broken off where do i find a repair manual
    Guru:
  • 285 Answers
Ull find in hp.com
Posted on Jun 03, 2010
Paper jam probleme
There is a chance that you have some bits of paper in the paper feed. This can cause the jam. Take the paper feed out and with a straw simply blow out and paper dust and pieces. Turn off machine first. There is something physical in the way causing this and not software related.
Jan 07, 2015 | Brother DCP-J315W Inkjet Multifunction...
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer says paper jam and ink is finish
No it will be miss feed or feed mechanism broken...
Matt
Jan 22, 2009 | HP PhotoSmart C4385 All-in-One Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper does not go into the printer. One corner of a page will go down a bit but not the rest. There is no paper jam or any other difficulty.
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Nov 19, 2007 | HP LaserJet 2420 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
