Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printer will not print
The printer is churning the paper through but does not print anything on the paper. I have replaced the colour cartridge as this was low to no effect. it is still not printing.
    Guru:
  • 285 Answers
Reinstall usb and printer drivers and check settings
of printer
see that head of cartirage is ok
nozzels shall be jammed
Posted on Jun 03, 2010
My Lexmark Pro 905 has stopped printing colour. All cartridges are full.
Does the ink stuck up for a long time. I mean you do not print anything for long period of time? If yes, the ink dries up and try to clean the ink head by using rubbing the ink head cartridge to plain paper with isopropyl alcohol.
If not, the best way if to replace the ink cartridge and it will be fine printing.
Feb 28, 2011 | Lexmark Platinum Pro905 multifunction...
Black cartridge does not put anything on paper colourcartridge prints colour and black and white.fitted new cartridge still the same.
check expire date on cartridge
if it pass you need to replace them
with fresh one or refill the old ones
If i helped you pls vote me
Oct 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer stopped printing colour
Are you using Name brand ,new ink cartridges?
Take the color cartridges out and make sure you removed the tape from the bottom of those cartridges. if done already take a wet paper towel and squeeze out the excess water, then lay the damp paper towel folded in half on a flat surface.
Then set the colored in cartridges one at a time with the ink side pressing against the damp paper towel for about 3 min. after 3 min you should see the ink drain on to the paper towel if so then replace the cartridge back into the printer and that should solve your problem.
Feb 14, 2009 | Canon i850 InkJet Photo Printer
PRINTER MAKSE A CHURNING NOISE
Do a half self test. To do this print anything and open the cartridge door when paper feeds into the printer but before it reaches the fuser. This will tell you if problem is with toner or fuser. In order to check the fuser remove toner, in back of printer you'll see a cover held in by 2 screws. remove screws and gently pry cover enough that you can shine flashlight and see the fuser film. If torn replace fuser.
Dec 29, 2008 | HP LaserJet 3030 All-In-One Printer
Unable to print anything because of continual paper jams. I can clear them with difficulty, from the rear of the printer. This first happened after I printed a colour picture and immediately tried to...
Papper Jams = Old Paper Feeder Rollers
1. Buy new printer.
or
2. Replace Paper Feeder Rollers.
Thank you for choosing FixYa!
Azkeyz. Wizard Division.
Sep 23, 2008 | HP Office Equipment & Supplies
Colour printing
If its a Canon printer try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
Konica Minolta 2530DL
I had the exact problem with the paper stopping at the same point in the printer. The fault was not the paper feed but the fact that the drum stopped at this point due to a loose toner cartridge. I rotated the cartridge using the menu for relpacing it and removed the cartridge and then re-fitted making sure it was fully seated in the printer. It now works fine. I would check each of the toners again.
Chris
Dec 12, 2007 | Konica Minolta magicolor 2300DL Laser...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
99 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
