Question about Sony KP-53HS10 TV
Standby Light Blinking
I was watching tv then suddenly it went off and the Standby light started blinking continously... no code just blinking. I tried resetting the tv by unplugging it... waiting for 5 minutes then plugging it back in...still the same result... MY TV is a KP53HS10 Rear Projection TV. I downloaded the repair manual but it has no troubleshooting section in it. What do I do?
  • Anonymous Jun 16, 2008
    The TV will work fine for about 10 minutes then screen goes black and the stand by light starts blinking. Still has sound. If you turn off the tv, and turn back on immediately, it is fine for about two minutes or less. The longer it is off, the longer you can watch :(
    President:
  • 3,130 Answers
The service manual is for the technician who knows how to troubleshoot electronic circuits using the schematic diagram and test equipment. There is no such thing as a trouble shooting section in Sony service manuals. My best advice would be if you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Posted on Apr 09, 2008
2 Suggested Answers
JunZky_
  • 8 Answers
SOURCE: Standby Light Blinking
Standby light is a signal indicating a voltage trouble on your system . It could mean a compoment is defective or a power regulator needs replacement worse is a system IC replacing. you better bring your stuff to a Sony service center and do a check on your TV system.
Hi, I have a Panasonic Plasma TV and Was recently watching it when all of a sudden the screen went out. The light to the tv only blinks now and there is no picture. Any ideas what this problem isn't?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 17, 2015 | Panasonic Televison & Video
Some time ago, I was watching TV, then, all of sudden, the TV screen has gone, just like 'blank'. The main power (red light) keeps on blinking. Normally, it is just on, not blinking. TV doesn't respond at...
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 24, 2013 | Bush 5693D 24" TV
TLC television on stand by mode
Blinking of standby light at the front panel of the TV indicates internal circuit fault. Contact any experienced service technician.
Nov 22, 2012 | Televison & Video
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Jul 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Apr 09, 2008 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
287 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
