Question about Canon PIXMA MP610 InkJet Printer
My Canon PIXMA MP610 has a jam visible through the glass of the scanning bed - there is a "chain" that normally moves from left to right during the scanning process, but it has jammed up and I can see that it's stuck in one position. The printer cannot perform any functions - as soon as I turn it on it freezes up and the chain attempts to move, but instead it just clicks in place. I then get an error code telling me to power off, then power back on. I've tried this multiple times. How do I get into the scanning bed to fix this? Thanks!
  • jenn3984 Jun 03, 2010
    Do I just unscrew all the screws underneath the scanning part? I don't see any that lets me take the glass off.
    Guru:
  • 285 Answers
If its warranty give them or open it and do it urself
its easy
just grease the tracks
Posted on Jun 03, 2010
Error 5010
You have a scanner error. Most likely its a dirty sensor under the scan glass.
You would need to partially dismantle the scanner bed and clean the home
sensor. A tricky proposition without the right tools.
Mar 23, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Where is the serialnumber of the Pixma MP620 printer?
with the front panel down, lift the top cover and the glass scan screen panel, this will reveal the ink cartridges, wait until the cartridges have moved left then look down to the right of the cartridges, on the silver chassis you will see the serial number.
Feb 21, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I have a Canon MP610 printer and am getting an error message 6A00. I have tried moving the carriage but nothing seems to help. Any suggestions?
1. Turn off the printer
2. Open cover
3. Print head and cartridges manually move to the left
4. on the extreme right is a white plastic cover is visible, which is attached to a spring
5. Clean the cover carefully (no chemicals, not wet) and gently push it back (it clicks) and remove any impurities -> the black collecting sponges for the storage of the print head can see
6. Print head and cartridges manually back to the right move
7. Turn on printer
If the above steps does not fix the problem, Click on the link below to check the forum for more details on resolving the issue.
Canon Mp610 Error 6A00
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | Canon MP610 Photo All-In-One Printer
Can I save a scanned image using MP610?
Yes. PIXMA MP610 is a multifunction printer that has printer/copier/scanner capabilities.
Just install the software and drivers supplied with your printer (or download them from CANON ) and connect the printer do the computer.
The printer sofware will guide you through the operation of scanning an image and saving it to a a file in the computer.
Below is a link to CANON product support pages, from where you can dowload the software and drivers for the printer and also guides and manuals.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelTechSpecsTabAct&fcategoryid=2610&modelid=15604
Jul 27, 2009 | Canon PIXMA MP610 InkJet Printer
Canon PIXMA iP4600 - error 6A80
Hello someone else here had this problem, this is what he posted: "Same problem with a Canon MP540 fresh from the box. Turned out to be the print head unit was not returning fully to the home position ie extreme right. My Fix : When the scanning unit cover is raised the print head unit moves left for access, look in the vacated area to the right, in particular the small black sponge where the head normally parks. I found a small spring jammed in beside the sponge, removed it and all is well. Don't know what the spring was meant to do but everything is working fine without it.On the MP540 the head unit now glows red, presumably meaning all is well... "
Jun 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
May 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MP610 PRINTER ERROR 6A00 LIGHTS FLASHING
You can try to reset it back to factory by removing the printhead and all cartridges.
Power off the unplug from wall for 30 min.Reverse procedure and see what happens.
From what I am reading is the carriage will not lock on the left!
Correct?
Try this and let us know.
Mar 24, 2009 | Canon PIXMA MP610 InkJet Printer
How do i scan a document?
Place photo on glass platen, then got to START
Start button, Canon Utilities, Solution Menu, Scan/import, photo/platen, then press big green button.
THen have fun scanning it is fantastic
Jan 23, 2009 | Canon PIXMA MP610 InkJet Printer
Printer problem
During a normal scan, the light source moves across the large glass pane reading the entire area. When using the ADF, the light source remains stationary below the small small glass pane to the left. Check for smudges or specs on this glass area. We had the same problem, and cleaning the small glass pane worked.
Mar 08, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
69 people viewed this question
old marine
old marine
