Question about Honeywell MT-SY-HWLM2216 22" Monitor
Humming from back of monitir
This the first and only promblem with it, I had a three year warranty on it but who can I contact.
    Guru:
  • 285 Answers
What is the company ill will help u out
give ur serial no
and model no
and name of manufactrer
Posted on Jun 03, 2010
Lg tv humming noise when tv is on
The humming noise is most likely coming from the power supply.
If the unit is worth the repair cost ( Over $100.00 ) you should have it repaired.
If not, deal with the noise until it goes out.
May 12, 2014 | Televison & Video
Loud huming from my 300v low voltage lighting transformer
Transformers make humming sound.
ML300 series transformers make sound.
Used styrafoam to separate transformer from contact with building so sound is not carried.
These transformers have 10 year limited warranty.
Copy following link for general troubleshoot and tips, and warranty information, and trippers.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 23, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
Transformer is Humming loudly, how do I stop
Some make more sound thAn others.
Oct 23, 2012 | Intermatic Malibu 300W Power Pack...
Do i have a warranty with my mouse?
It has a 3 year limited warranty which basically covers defects and poor craftsmanship. If you have had it less than 3 years and you think the problem is not due to wear & tear then contact Logitech for a replacement.
Mar 07, 2011 | Logitech Marble Mouse Trackball
No suction and pump turns on but makes a humming sound. it is only 4.5 years old.
ok the humming sound can be one of two things. The worse case scenario is the motor is frozen and therefore dead. On the flipside tho sometimes it can be as simple as something binding on the impeller so that it cant get its initial spin and thats why it makes the humming sound and would eventually throw (trip) the breaker. The way to test is to first *****************MAKE SURE THE POWER TO THE MOTOR IS OFF***************** AND THAN DEAD CENTER ON THE BACK OF THE MOTOR (basically oposite the basket ya know where the noise is) THERE WILL BE EITHER A CAP THAT LOOKS LIKE A NUT AND WITH A QUARTER TURN IT WILL COME OFF OR THERE WILL BE A INDENTED OR INVERTED CAP WHICH YOU WILL NEED A THIN FLATHEAD FOR AND YOU TAP IN A COUPLE SPOTS TO PRY IT OUT. EITHER WAY WHEN YOU GET THAT OFF YOU WILL SEE THE END OF THE SHAFT. ( Its made out of stainless and its flat on two sides so that a 1/2 inch wrench can fit on it). IF YOU THAN TURN THAT SHAFT AND IT SPINS FREELY YOU PROBALY HAVE A DEAD MOTOR. IF YOU SPIN IT AND IT FEELS A LITTLE GRINDYTHAN MAYBE SOMETHING IS STUCK IN THE IMPELLER. IF THATS THE CASE GO AHEAD AND MAKE A FEW ROTATIONS AND THAN TRY TURNING ON THE PUMP AGAIN TO SEE IF THAT HELPED TO GET IT TURN OVER. MAKE SURE NOTHING IS ATTACHED WHEN YOU TURN IT BACK ON.
Pentairs warranty is one year if you just bought a pump by itself and three years if you have three or more major pieces of Pentair or Sta-Rite equipment installed at the same time. Also the warranty is for the original owner only it is non-transferrable.
Some of the common causes for this condition is if the basket in the pump ever cracks than stuff can get pass and clogg or bind the impeller. Now dead center on the shaft and the motor is whats called the Ps-1000 mechanical seal and if that develops a leak that isnt noticed or caught for a while than eventually the water from the leak will make it back into the bearings and windings of the motor and cause it to die.
Dec 29, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
Jul 13, 2010 | Rheem Tankless Hot Water Heater...
My side by side makes a loud humming noise from the freezer when the frig is running can you help solve this promblem or do i need to buy a different brand to solve this promblem for the second time
most likely it is the evaporator fan motor.you can replace it but know telling how long the new part will last.not very expensive part but very easy to replace.once you take the back panel off in freezer you will look above the coils and you will see your fan motor.
Mar 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Dell - 17" flat screen
This sounds like the back light is gone on the monitir... to check this look very close at the monitor whet the PC has booted, if you see a VERY dim image on screen then it suggests that the back light is gone.
Many monitors hace a 3 year warranty so I would try a warranty claim before throwing it away
Jul 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
3 year old unit, oven works, microwave does not
hi,
You may need a new magnetron, contact sharp or the store you got it from; most microwaves have a 3-5 year warranty on the magnetron. If it's not in warranty, find a good appliance repairman, this is a difficult and dangerous repair job.
Apr 03, 2008 | Microwave Ovens
Honeywell MT-SY-HWLM2216  22" Monitor Logo
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
