Question about Lexmark All-in-One Printer with PictBridge
Printer cartridge missing
Wont print color and i replaced black and color cartridges and still wont print color or black and white
  • Anonymous Apr 17, 2008
    My Lexmark is giving the same error with a new color cartridge-- the old one that's almost empty still works. I am going to return the color cartridge for a refund.
  • 48 Answers
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Posted on Jun 18, 2008
Unable to clear missing/damaged cartridge msg even after cleaning.
why does my printer say ink cartridge missing or damaged ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Aug 8, 2012 - 10 posts I recently changed my ink cartridges ( colors and black) and now it says that the ... why does my printer say ink cartridge missing or damaged? ... cartridge from Office max and it still has the message and I am unable to print. ... Remove the cartridge and take a close look at the tiny circuit card on the section ...
Nov 30, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Wont print in color only black and white
wrong cartridge or needs cleaning the contacs
Dec 15, 2009 | HP DeskJet D2560 InkJet Printer
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
The color cartridge runs out very quickly even though I rarely use it. I make sure to print in black and white, and I manually choose the option "Use Black Cartridge only" but the color cartridge runs out...
Printer manufacturers design their printers to print some color mixed in with the black when you are only printing black. That is why your color cartridge is running out when you only print black and why it prints "weird colors" when the color cartridge is empty. Printer manufacturers sell the printers at a loss and make up the profit on the cartridges.
Feb 20, 2009 | HP D4360 DeskJet Printer InkJet
Printer not working!
Usually black is provided by the black cartridge only. You might be able to setup the printer through the control panel using black and white printing until the color cartridge is replaced. That might turn the color cartridge off allowing you to print.
Jul 27, 2008 | Lexmark Z1300 InkJet Photo Printer
Lexmark All-in-One Printer with PictBridge Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
