Question about Dometic RM2193 Compact Refrigerator With Ice Box
I have a mid 70's Dometic RM 211 refrigerator in my camper. The screen on the propane burner has been damaged and needs to be replaced. Parts no longer exist from Dometic. What size wire mesh do you recommend for this screen? What metal should it be? Thanks so much, Brian
  • 905 Answers
Hi Brian,
You don't want to use a screen that is made to fit. The original part was designed for a specific flame. That being said, colaws rv salvage may have a replacement burner in stock, and you can also try calling up a company that rebuilds cooling units for rv fridges.
Posted on Aug 16, 2010
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Dometic rm 183
check gas pressure if ok clean lines to ignitor and blow out orfices
Apr 27, 2013 | Dometic RM2852 Refrigerator
Dometic RM2652. The fridge will not work when it is plugged into AC.
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Apr 30, 2012 | Dometic RM2652 Refrigerator
I have a dometic rv fridge. it works on the 120 v but not on propane. acutually the freezer works and the fridge is warm, when the propane is running the fridge
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jun 04, 2009 | Dometic NDR 1292 Refrigerator
Won't get cold anymore
Good thinking... you need to hire a service technician (a good one!). Too many jackasses think they know these systems. Obviously, there's something wrong with the system.. if so, you need someone who knows what they're working on/with.
May 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
No propane
Yes it can also run on 120 AC and 12 volt DC
Here is the website. If you need help in understanding let me know
http://www.campingworld.com/shopping/item/dometic-rm2193-compact-refrigerator/13473
Apr 21, 2009 | Dometic WA3210 Compact Refrigerator
RM 2611 2-way ref. will not run on propane
replace the thermocouple cost is 12 dollars this is what holds the pilot lit thanks from gilles
Jan 30, 2009 | Dometic RM2652 Refrigerator
Dometic RM2193 Compact Refrigerator With Ice Box Logo
615 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
