Question about Tascam DR-1 MP3 Player
I cannot get updates and this error appaers -ox800703EE how can I get updated?
    Guru:
  • 285 Answers
Flash it
do an firmware update
Posted on Jun 03, 2010
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
Hi my mum has just purchased windows 8..can get onto facebook...but when she wants to play mindjolt games..(golf solitaire) it will come on... but then has a white screen where the game should be.altho it...
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this: Install the Windows 8.1 Update (KB 2919355)
  • ?Email
  • Microsoft support. Code 0x800F0922 This error might mean that a file needed by Windows Update is damaged or missing. Here are a few steps you can try to fix the problem:
    1. Run the Windows 8.1 Update troubleshooter to fix the problem.
    2. Install the Windows 8.1 Update or Windows RT 8.1 Update.
    Code 0x800F0923 This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support. Code 0x800F0922 This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
    The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition. Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
    Error: Failure configuring Windows Updates. Reverting changes. These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
    You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
    To view your update history:
    1. Open Windows Update by swiping in from the right edge of the screen (or, if you're using a mouse, pointing to the lower-right corner of the screen and moving the mouse pointer up), tapping or clicking Settings, tapping or clicking Change PC settings, and then tapping or clicking Update and recovery.
    2. Tap or click View your update history.
    Error: The update is not applicable to your computer. This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
    To refresh you PC:
    1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings. (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click Settings, and then click Change PC settings.)
    2. Tap or click Update and recovery, and then tap or click Recovery.
    3. Under Refresh your PC without affecting your files, tap or click Get started.
    4. Follow the instructions on the screen.
May 07, 2017 | Computers & Internet
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Windows Update error code 80070103
This windows update error code means you already have the latest drivers installed onto your computer and you don't really need to upgrade it.
To know more, follow this link: Windows Update error code 80070103
or you can also visit: Update error Code 80070103
Hope this helps, Mrityunjay.
Jun 16, 2012 | Computers & Internet
I have Windows 7 Home Premium desktop. When I try to back up to DVD the back up stops at 25% with error code Ox800703EE with the message "the volume for a file has been externally altered so that the...
That error is because the backup ID when it starts to back up becomes different as the DVD fills up.
I would backup to USB, faster and easier to use.
If you wish to backup to DVD use a backup utility like Norton Backup or Acronis etc. They can make an image file first and avoid this problem.
Dec 21, 2010 | Computers & Internet
I have just recently goting kingdom hearts birth by sleep and it will not work on my psp. my system software is 5.50 gen-d3. when i click on the umd icon to load game it takes me to a blank screen for 10...
hi buddy... i will help u to fix this problem..
My friend too faced same kind of problem ............
with his psp it doesn't get start at all.....
If you are also facing exactly same problem
then dont worry
Go to this site and fix your problem by downloading repair guide
Click Here to get guide
Oct 11, 2010 | Sony PlayStation Portable (PSP) Console
Update KB946140 and Error Code 646
Sometimes MS update has compatibility issue.Better no to install cause sometimes it can create a bug (Blue Screen Crash) to your system.Try to restore yor windows 7 to an earlier point and the error message gone.Also try to turn off your automatic update so that you can choose your update to be installed.
Nov 09, 2009 | Microsoft Outlook with Business Contact...
Microsoft updates
Most of the time when updates cannot be installed, is because you have installed a file that is newer than the one provided by Microsoft, or you already have the "update" and Microsoft gives you the error.
Essentially when your computer communicates with the Windows Update website. It uses TWO technologies called:
Active X - to interact with the Microsoft site. The first time you visit the Update website, using your profile, you are asked if you will accept the Windows Update Control Package (the Active X control) onto your machine.
SSL (Secure Socket Layer) - A method of data encryption used by Internet Explorer.
Now this general error message 0x800A138F, that some folks get when they visit Windows Update, has been around for a while. BUT, when the MSBlast virus was unleashed Microsoft changed a few things at the main update website. One of them was to use Akamai for additional bandwidth and this connectivity is exclusively using HTTPS (SSL) for the downloading of the update catalogue. It is since then that we have seen an escalation in the number of 0x800A138F error messages!
The following steps will help many of you... BUT
What would be REALLY helpful to anyone trying to support you, is if you go to the "Windows Update Log" and look for any "Errors". This gives a clearer indication as to the exact nature of the problem. (The 0x800A138F error message is a "General" error THE real error number is in the log. A list of possible error messages is in a table at the bottom of this page.)
The windows update log is in the following places:
C:\Windows\Windows Update.log (Win XP & Win98/Me)
C:\WINNT\Windows Update.log (Windows 2000)
Just copy and paste the above in Windows Explorer to open the log file...
Feb 26, 2008 | Microsoft Windows XP Professional With...
Turbo tax
Go to this website http://turbotax.intuit.com/support/kb/update/update/2201.html?lid=stic double click the link maualy update your Turbo Tax hope i help you with your problem :p
PS:
or
Error 9111 indicates a connectivity issue:
An error occurred while we were checking for TurboTax updates and we could not connect to the program update system.
Your computer's firewall or other security software prevents TurboTax from accessing updates on our server. Error 9111 will continue to occur until you resolve the issues caused by your firewall.
Do one of the following:
  • To temporarily work around this issue, manually update TurboTax.
    icon_note.gif Note: Manually updating TurboTax does not resolve connectivity issues caused by your computer's firewall. We recommend you address these issues before attempting to update TurboTax again.
Still can't update? If you still have problems updating TurboTax, order the free update CD. To order, call us toll-free at 800-624-8384.
or
It's Blocked with your Firewall try UnBlock it to your firewall
for Firewall removal instruction click this link:
http://turbotax.intuit.com/support/kb/connectivity/firewalls-and-anti-virus/113.html
Feb 24, 2008 | Microsoft Office Outlook 2003 for PC
Tascam DR-1 MP3 Player Logo
335 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
