Question about Kyocera FS- 4000DTN Laser Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Hi, we have a Kyocera FS 4000 DN printer that stops after printing about 40 to 50 pages, gives a paper jam message but there's no actually paper jam, just need to open the cassette door, then close it, it will keep printing for a while, then same thing happens again, opens the paper tray, close it, keeps printing, stop... you get the story... anyone have seen this issue before?
  • 62 Answers
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Posted on Jul 07, 2010
Kyocera FS-2000 dn error 7410-0001163 What is the problem ?
Call Sevice 4710 means the Connection between fhe Drum-Kit DK310 and the DV 310 is broken.
Open the Door on the left side, and push the Drum DK310 into the printer, so you here a klick,
Power off the printer and then power on the printer.
The Call 7410 Message is away, the Numbers after 7410 are the pages of printing
Oct 04, 2012 | Kyocera FS-2000D Laser Printer
Kyocera fs 3920 dn printer ripping paper when it prints
Hi, dear; it have to be something stuck in the paper path, do following way; make a copy after 2 second stop the machine,pull out the paper,see there have been rip on the corner, if yes check that area, if not do next copy after run for 4 second , stop the machine, pull out the paper check it again until you found out the rip happen, the paper chip should be there. good luck
Aug 31, 2012 | Kyocera 1102J12US0 Model FS-3920DN Small...
Hello, I have problem with Printer Kyocera FS-1300.. when i connect it to pc, it starts to print some symbols, like smiley face on left corner of page, and i cant stop it, when i disconnnect my device...
Hi. I would suggest that you unplug the printer, reinstall software and check you computer for viruses. If i continues, try letting it print out. maybe someone set so that 30 pages with a smiley would be printed next time you plugged it in. I how this will fix you problem.
Jun 08, 2011 | Kyocera Fs-1300d Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
Error code C70000
Hello, the code 7000 refers to the toner motor, but if you check my blog and there I have the full service manual. I hope you let me serve a Comment
http://tiototos.blogspot.com/ press click
Mar 16, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera FS-c5030N printing pages yellow
Push in the charge corona assy. Its behind the left door. Each color has a cleaning rod and charge assy. I've seen this more than once.
Aug 27, 2009 | Kyocera FS-C5030N Led Printer
Pages writing over each other.
Hi Bobbie,
If you are still having a problem with you FS 4000 printer I would suggest a firmware upgrade.
They change from one country to another so you will have to access the firmware locally.
This usually fixes silly problems such as this.
Mar 25, 2009 | Kyocera FS-4000DN Laser Printer
I have a kyocera FS-2000D printer. I'm getting an error message: insufficient memory. It will print first page, then stop.
check the basic user guide Chapter 4 - Troubleshooting pages 4-5 to 4-10 about a specific error message.
Make sure you are using the latest print driver from kyocera website !
If is really need it you can expand the memory !!
Dec 30, 2008 | Kyocera FS-2000D Laser Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera FS- 4000DTN Laser Printer Logo
505 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
