Question about Sennheiser (EW165G2A) Professional Microphone
Short static burst
I'm getting a very short burst of static periodically on one of the ew100g2 handhelds. Any ideas?
    Scholar:
  • 121 Answers
I don't know a whole lot about microphones, but if it's wireless, then it has to accept interference according to the FCC. Wireless microphones normally connect using RF transmitters/receivers which can normally be tuned to specific short-range broadcast frequencies, which can be interfered with by passing waves of other frequencies. Even if the broadcasted radio waves aren't the same frequency, or within the same bandwidth, the harmonic distortion radiates at multiples of the fundamental (broadcasted) frequency.
If you can, try changing channels and see if that clears things up. If not, then perhaps contacting the manufacture can help.
Posted on Jun 03, 2010
No tv picture and intermittent audio
Check the cables and connections
Apr 13, 2014 | Tatung Televison & Video
Can't pick up any talk on my cobra 75 ws xt cb radio
Was your antennae set up professionally? You may have a short in the cable or connections or even a bad antennae and/or a bad match. Was it matched with an SWR meter? Have these checked out because it does sound like an antennae or cable/connector issue.
Jan 31, 2014 | Cobra 75 WX ST 40-Channels Handheld CB...
Black and decker handheld vacuum phv1800 type 1 low battery power
Hi I know what you mean! My B&D dust buster used to do this too. The hi power boost means that it can only be used for a limited amount of time. Due to the age of the dust buster though its a sign that the battery is on its way out and regardless of whether or how long its been used or not used, batteries can lose power regardless.
Try to let the dust buster completely lose power and then charge it up for its initial burn in period of 14 hours. Also clean the connection metal strips or hole with a dry cotton bud incase there's any static or dust. Then see if it lasts longer. If the turbo mode or speed 2 is still short, then the battery is dying out.
I don't know where you are but in the UK its hard to get battery replacements for B&D products. You could check your local seller where you are if they have battery replacements but at the cost of current dustbusters it may make more economic sense to consider buying a new dustbuster.
Jun 19, 2009 | Vacuums
Static
me too! but not with my head phones all the way down. for some reason this static ends up on my recordings too. i dont get it. it is like short bursts of static every 6 seconds or so. i would greatly appreciate any information if you have found a solution yet. THANKS!
Jul 08, 2008 | Digidesign Mbox 2 Barebone
Scanner static
Use the channel lock out control, unless it is a frequency that you listen to, you may have interference that is causing random static. use a noise filter mechanism to minimize this problem, or buy a specialized scanner antenna that's guaranteed to minimize static.
If no avail, you may need to send it in to a store.
Hope this helps!
Jul 01, 2008 | Uniden BC60XLT-1 Handheld Scanner
Cobra Cb handheld radio model: HH-35 doesn't work
Open up the back of the radio and check the solder joint from the antenna connector. I had same problem and it was this.
Mar 23, 2008 | Cobra HH 38 WX 40-Channels Handheld CB...
Having Trouble Receiving Through"TPL"
Are you sure that you are using the exact RX Frequency? is the radio in 25Khz if this radio is working on 12.5Khz with the IF filters changed to work in narrow band (12.5) could happend this.
Do you know if the repeater is on parameters mostly of the cases when an over modulation is received this will cut the PL modulation for short periods.
If the radio transmit over modulated could "erease" the PL modulation for short periods.
I think this radios should be checked all the Tune parameters to make sure is ajusted properly.
Good luck
Dec 17, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Amp turns off or goes to protected mode during long low base
Let me take a stab at it There are two types of resistance... Static and dynamic. These resistance change depending on the position of the cone. Now im guessing the short bursts of bass are not small ones. If the cones are forced further than allowed the resistance of the combinded drivers may drop below the rated impediance for the amp...causing the amp to into protection to keep itself from over driving itself (the less reistance a amp sees the more power it will produce, till it essential blows itself up)
Mar 16, 2007 | Pioneer TS-W256C Car Subwoofer
Sennheiser (EW165G2A) Professional Microphone Logo
233 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
