Question about Briggs & Stratton Garden
Starter motor whirls, does not engage / start engine. Battery is fully charged
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
The starter is actually an assembly with a motor and a solenoid. The solenoid does two things: it closes a contact to send electricity to the motor, but it also moves a gear on the motor shaft upward to engage a gear on the engine flywheel. Most likely, you will have to replace the starter assembly to fix this.
Just in case, you should also check the gear on the engine flywheel. It's where the starter pinion engages. If it's missing several teeth, you could just be in that 'dead spot'. That can temporarily be solved by turning the motor a little bit to get to a good spot - but remove the sparkplugs first! And eventually you'll end up in the dead spot again. It is a more expensive repair.
Good luck! Please rate if you find this helpful, thanks!
Posted on Jun 04, 2010
My 83 Honda shadow 750 vt won't start it whirls, it has a new a battery and have check gas lines. Pls help
The whirling your describing sounds like your describing a whirling starter that's not turning the motor, the starter is just spinning internally. Bad starter if so. Check the teeth on the flywheel if u pull the starter too.
Aug 16, 2017 | Honda VT 750 Shadow Motorcycles
What could be broken on my Saturn ion? It tries to turn over but all I get is a whizzing or whirling sound. The last time it did start I was getting a clicking noise moving or not, the higher the RPM's the...
I would guess (without further info from you) that the solenoid on the starter OR the starter itself require R&R. (presuming that you battery is fully charged)
Mar 28, 2015 | Saturn Cars & Trucks
2011 ford focus 1.8 clicking noise when start engine
Could be several problems - check the battery terminals to make sure they are clean. Next check the battery to see if it is fully charged. If both those items checked are OK then the next step is to check the starter.
Now the starter has a selenoid which engages and provides power to the starter motor when you turn the key to the start position.
If you only get a clicking noise then it could be the selenoid valve itself or the starter motor.. Some fords have the selenoid mounted on the firewall others are mounted on the starter motor itself.
So what you need to do next is bypass the selenoid valve and provide power directly to the starter - if the starter turns the engine over then the selenoid valve is the problem. If the starter motor doesn't turn the engine over then it's the starter motor and a replacement is necessary.
Hope this info helps.
Feb 22, 2015 | 2011 Ford Focus
Vx v6 auto commodore wont start
could be a neutral switch key switch you have to check to see if you are getting voltage to small starter wire going to your starter motor .and if you are problem could be in starter
Nov 01, 2012 | 1998 Holden VT Commodore
I have a 1999 vw beetle diesel that the starter does not engage when I try to start. I have a new battery that seems to be fully charged but the lights dim when in start mode but there is no noise.
Then remove the electrical starter motor out from the engine, and repair it by replacing the engaging coil & electrical brushes (if necessary).
Nov 24, 2010 | 1999 Volkswagen Beetle
STARTER WONT STAY ENGAGED LONG ENOUGH TO START ENGINE - STARTS TO CRANK AND THEN SOUNDS LIKE IT's FREEWHEELING
Almost certainly a discharged battery ( have the battery fully charged ). - If that doesn't solve the problem then check the wiring connections to the starter motor, if they are loose or corroded they can overheat,also resulting in the symptoms you described. Tell me how you get on and Please leave feedback!!!!!
Jan 26, 2010 | 2002 Yamaha V Star Classic
2001 mustang gt,all access. work fully charged
I would suspect the starter solenoid has failed.
A starter solenoid (or starter relay) is the part of an automobile which relays a large electric current to the starter motor, which in turn sets the engine in motion. In many vehicles the solenoid also engages the starter pinion with the ring gear of the engine.
The starter solenoid receives a large electric current from the car battery and a small electric current from the ignition switch. When the ignition switch is turned on, a small electric current is sent to the starter solenoid. This causes the starter solenoid to close a pair of heavy contacts, thus relaying a large electric current to the starter motor, which in turn sets the engine in motion. The starter motor is an electric motor that initiates piston motion in a car's internal combustion engine before it can power itself.
Nov 27, 2009 | 2001 Ford Mustang
96 Achieva has starting problems
The solinoid switch on yor starter is not engaging the engine flexplate; charge your battery then try again if the engine starts replace the battery if the car does not replace the starter.
the solinoid gets weak and needs more power to push into the flexplate and, the switch contacts in the starter can also get burned increasing the need for more power to work properly also check the battery cables they must be clean and, tight
Apr 21, 2009 | 1996 Oldsmobile Achieva
Starter on 1200 L 2006 whirs but does not engage engine to start
Have the battery LOAD tested, a lot of times a battery will show good with no load on it but it can actualy be bad when tested under load. Also make sure your grounds are good clean and tight. Loose grounds is a very common problem with the 1200 sportsters.
Apr 17, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Renault 1.5 DCi -Starting problems
The ticking sound is the solenoid striking the high current switch to engage the starter. If the starter motor will not crank the engine, it is possible that the battery is under charge or the starter motor would not turn. In some extreme cases, the reason that the starter motor will not turn is because the engine has seized. To determine whether it is the starter motor or the solenoid, you can try jumping the two big terminals of the solenoid to apply straight +12 to the starter motor. If it cranks, then it is the solenoid, if not then it would be the starter motor itself. Of course pls have the battery checked and/or fully charged.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 17, 2008 | 2005 Renault 181
Garden Logo
454 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
