Question about Apple iMac G5 Desktop
A fine vertical blue line running through imac screen
A fine vertical blue line running through my four year old intel iMac screen. I have read that it indicates that the screen is starting to fail... How long might it last before it does finally stop working?
    Guru:
  • 1,705 Answers
How long is a piece of string? is the kind of question you've asked. I've a sneaking suspicion you'll get sick and tired of it before it finally goes.
Posted on Jun 03, 2010
Imac intel blue screen
Can you start up in Single User Mode? Restart and hold down the command/Apple & the "S" key.
Apr 17, 2012 | Apple iMac G5 Desktop
Imac os intel core 2 duo inverter
Pop in your OS X DVD and run a repair install or an archive and install.
Shortly after the warranty was up the first vertical yellow line appeared and now, about 1 months later another vertical line appeared. He's not happy to hear it only gets worse and apple won't do anything...
Although its possible for graphics processor failures to cause vertical lines, they more often create horizontal ones. The first culprit to check for a vertical line problem is the LVDS cable, which it turns out is not that expensive a part (not counting all the work there is in getting to it). To verify this, I would gently flex the cable while the iMac is open and operating, and see if the lines get better or worse. It may also be that the cable itself is fine and just a few of the connector pins at either end are intermittent, in which case it just needs reseating.
Oct 18, 2010 | Apple iMac G5 Desktop
I have an iMac 17" that has just started to have a vertical line - blue in color. How can this be fixed? It's 3 years old and nowhere near a technical support person.
Hi this is a known problem and will terminally get worse with the only solution being to get a new screen being over £300's.
heres someone who could help you http://www.gumtree.com/london/54/66321154.html
Sep 30, 2010 | Apple iMac 17" Desktop
I have two lines in my screen one is bleu and the
If this is a new machine (less than a year old) you should contact Apple's official tech support through the options listed here:
http://www.apple.com/support/contact/
It sounds like a possible hardware problem.. either a bad display, graphics chip, or internal video cable connection.
Aug 06, 2009 | Apple iMac G4 20" Mac Desktop
Vertical line in imac 17" core 2 duo intel 2006 model
Attach an external monitor (you may need to buy an adapter to try this) and turn on Display Mirroring in the Display preferences.
If the same symptom shows on the external monitor, then you've got a video card problem. If not, I'd say you're screen has some kind of damage of failure.
Sorry, but either one is likely going to require a trip to the Apple Hospital.
At least with the display problem, you could use the external monitor until repaired.
Mar 16, 2009 | Apple iMac G5 Desktop
Bad graphics card on an Intel iMac?
Lines on an iMac are usually a sign of a bad monitor not video card. The technicians at the Genius Bar are anything but genius.
Dec 26, 2008 | Apple (661-2795) for iMac Motherboard
White vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
Dec 15, 2008 | Apple iMac G5 Desktop
Screen Changes and Comupter freezes
It may be possible that the power supply, display and or logicbpard may be having issues. Apple recommends resetting the pram and nvram. If issue persists reset SMU. YOur machine is 6 months outside of the original warranty, but if you purchased the 3 year extension plan, you may want to take action on it.
http://search.info.apple.com/index.html?q=imac%20g5%20reset%20pram&lr=lang_en&search=Go&type=
http://search.info.apple.com/index.html?q=imac+g5+reset+smu&type=&search=Search&lr=lang_en&search=Go
Keep me posted.
Nov 10, 2007 | Apple iMac G5 Desktop
Apple iMac G5 Desktop Logo
1,053 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
