Question about Sony PlayStation Portable Silver Console
Our PSP will not turn on , I think Nick doesnt turn it off in order to save his game . I did not purchase a memory stick
    Scholar:
  • 121 Answers
The battery may be dead, but first make sure that the hold button isn't on. Try turning it on while it's plugged into the charger and switching the hold button to its different positions.
Posted on Jun 03, 2010
How to download psp games into my pc
Hi there, I came across an article which explains how to transfer PSP Data to your PC.
CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
FORMAT YOUR MEMORY STICK
In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
EXTRACT THE SAVED GAME
This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
VERIFY TRANSFER OF SAVE DATA
To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
Jan 01, 2011 | Sony PSP (Piano Black)
How to make download games from computer to psp
Hello
EXIT USB MODE
That's it, simple and smooth.
Oct 12, 2010 | Sony PSP (Piano Black)
Can't get game to save
have you tried formatting the memory stick. go to settings>system settings>format memory stick this helps about 7/10 saving file problems. my experience has been that you get a better format if you have your psp connected to your pc and format it that way. this could have been a problem with your existing memory stick but i don't know why it did it to the new one... hmmm
Dec 27, 2009 | Konami Brooktown High for PSP
Storing games/music on the memory stick
press select button then when you see the CPU CLOCK XMB just turn it into 333/166 and also the CPU CLOCK GAME turn it into 333/166 and the UMD ISO MODE turn it into Sony NP9660 and then exit...
Mar 29, 2009 | Sony PlayStation Portable (PSP) Slim...
I just purchased a sony used psp for my grandson.
Follow the directive below to;
Step 1. Put on your PSP and use the arrow keys to go to "Saved Data Utility". Scroll down to "Memory Stick" and press the O button to get into the games stored in your memory stick.
This would enable you play your games on your memory stick, but if you are still not able to do that then get a UMD to play games or verify the version of your PSP.
You can only play the games in the memory stick after the PSP has been hacked.
Regards
Mar 16, 2009 | Sony PSP (Piano Black)
When i put games in my sons sony psp it doesnt read them
You should reformat the psp memory stick if the game is copied, but for the UMD, for M33 versions firmware, you press Select on your psp and select UMD instead of memory stick. You should press the select on other parts of your selections on your psp. Do not press other things such as saved data utility, etc.
Mar 14, 2009 | Sony PlayStation Portable (PSP) Console
Goblet of fire PSP Can't save
I had the EXACT same problem....it would go no further that that looking for memory card screen....apparently the game will not accept that big of card....install the standard 128 or 256 mb card and the game will run normally...it worked for me...Good Luck :)
Darin
Dec 23, 2008 | Sony PlayStation Portable (PSP) Console
A guy
first, try other games to save a file. other saves. then try it again. if it still doesnt work, buy a new memory stick.
Apr 14, 2008 | Sony PlayStation Portable (PSP) Console
PSP Games
You most likely need to format the memory stick with the PSP. What may have happened is once you've upgraded, the PSP re-rooted itself into the memory stick. So it's looking for a folder that doesn't exist. (But that's just what I think...) I've had this problem also. After you format it with the PSP, it should work fine. As for your game files, they should still be saved on the memory stick. Search all your files with your computer then save them to your computer so they don't get formatted. After the format, put the files back onto the memory stick where they belong and everything should work fine! Please ask if you have any questions!
Jan 02, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable  Silver Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
