Question about Peg Perego John Deere Gator HPX
Gator was stuck in reverse and would not go into any other gears, finally got it unstuck from reverse but now it will not go in any gears. Any ideas what the problem could be.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Probably a bad shifter switch you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 08, 2012
  • 60 Answers
SOURCE: Peg Perego Gator goes in reverse
Your switch/harness may need to be unplugged and turned around. Take off the shifter and you can see it there.
Posted on Mar 11, 2009
  • 156 Answers
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 156 Answers
SOURCE: gator will not go in reverse or low gear only high
I would check to see if both wheels are spinning in high.
If only one spins, then it may have a loose connection on one of the motors.
You can also get the specific peg perego gator switches from the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
They also have a phone number that you can call them to explain the problem with the vehicle, they seem to know a lot about them.
Hope this helps.
Posted on Mar 18, 2010
How do I unlock the chuck to get the bit out
Finally got it the normal way. Put the drill in reverse. Hold the outside ring very firmly and slowly run the drill (in reverse direction). It was stuck. After about 5 bursts on the trigger, it finally came unstuck.
Sep 01, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Our childrens gator has had a new battery and still wont go properly, only have 2nd gear and no reverse or 1st. Any ideas?
the answer is it is the transmission 1st and reverse are the same gear on any vehicle it will have to come out and come apart dont worry if you dont know how if can do this once apart you are looking for a shifting fork that looks simular to a tunnig fork if you cant order parts a new trans or used trans will fix it or do what i do dispose of it.
Nov 21, 2010 | Peg Perego John Deere Gator HPX Ride on...
No forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Jul 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
96 escort manual 5 speed stuck in reverse
Is the stick moving? or is it 'stuck' in the reverse position as well? There are adjustments but it seems more likely that your 'stick' has come unstuck from the gear levers that actually put the gears in the right spot. Have someone look at the transmission while you move the stick to see if the levers are moving and put your response here.
May 08, 2009 | 1996 Ford Escort 4 Door
!st gear won't work
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
My 1996 mercury mystique wont go into reverse
not a frozen linkage....the cable could be stretched but you should be able to putit in a different gear and get reverse if that is the case..it my have messed up the transmission as well. take it to a shop and find out what they have to say
Feb 01, 2009 | 1995 Mercury Mystique
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Peg Perego John Deere Gator HPX Logo
75 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
