Question about Motorola Mobility H500 Wireless Headset
The device will not charge- no light comes on when plugged in to recharge, is the battery dead? Do I need to trash it and get a new headset?
    Scholar:
  • 121 Answers
Make sure (and be careful about it being unplugged and discharged) that the prongs/jack used to charge it are making contact. A bent prong or loose jack can cause problems like that to arise.
If nothing's bent or loose, then perhaps the battery IS dead. Call the manufacturer support line and they should be able to fully troubleshoot your problem. Most companies are nice enough that they'll cover you in situations like this one, especially if you make a scene about it if they're indifferent.
Posted on Jun 03, 2010
Headset won't recharge battery must be dead
That may very well be the case. There is a finite number of charge / discharge cycles a battery can handle. This number varies based on the level of discharge prior to charging, temperature, etc. Some devices can operate via charger alone - and others require a small amount of battery power and a charger to operate. A classic tell tale sign is an older device that has been used regularly and charged every day or night - but was allowed to fully discharge once - due to failure to connect to the charger. Attempting to charge may indicate it is accepting a charge but goes completely dead / dark when the charger is removed. That usually indicates a battery that was drained so low that it will need to be replaced. Good luck!
Oct 19, 2015 | Radio Communications
Does not switch on after fully charging night light works if charger is plugged into power point
will the main light come on when plugged in? it might just need a new bulb. if so it might be a dead battery
Mar 11, 2014 | Coleman Retro Rechargeable Battery Powered...
Cant get it turn on
It likely that rechargable battery is not taking a charge any further or the contacts point of plug are damaged. Sorry to say "it's dead, Jim."
Jan 31, 2013 | Jabra BT350 Bluetooth Headset Headset
Hi, i am having a wep250 bluetooth headset..i did not use it for a long time.after trying to use it after 8 months, i found that its not coming up..i tried recharging it..i checked the voltages from the...
Seems like Li-Ion battery is fully discharged. In this case internal charge-controller comes to shutdownd.
Before you send Headset to trash you can try to open it, locate battery, define it's legs - "+" and "-". Then try to connect two new AA battery (in-series) with pieces of wires to correct legs: "+" to "+" and "-" to "-" for up to one minutes.
Then try to charge by adaptor in 1 or more hour.
If you can, try to measure voltage on battery during charging or after: voltage should be about 3.6 v.
Try to switch on. If OK you can assemble headset but remember: the volume of battery can be less than new and maybe you'll need to charge it more frequently.
Apr 21, 2011 | Samsung WEP250 AWEP250JBECXAR WEP 250...
My bluetooth is not charging. the ligth on the charger comes on but on the actual bluetooth the light doesnt come on. Is this fixable or do i need to buy a new one?
Try and find a similar charger and test the device on that. if you have the same results than either the battery in the device is completely dead, or the device itself has malfunctioned and needs to be repaired/replaced. if the device is still under warranty you can try and contact the manufacturer for help or a repair/replacement.
Feb 28, 2011 | LG HBM-760 Bluetooth Headset
I've had my plantonics headset for two weeks now and has worked great. Today, however, when I went to turn the unit on after it was recharging all night, holding the power button did nothing. I plugged...
This is probably a problem with the internal battery.
Some devices do not need to be charged for a very long time as this leads to eventual destruction of their battery.
The only way i can specify for you is for you to do the following.
Put it on charge and try turning it on, see if it comes on. If it does, the battery may be spoiled so cannot retain charge to power the device as it may have been over charged.
Also, if this doesn't work for you, the only thing you can do is to send it to an accessories store for check up or for repairs.
Hope this helped you? Please comment for more information.
Jan 21, 2011 | Plantronics Backbeat 903 Bluetooth...
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
H670 wont turn on
same thing here. probably battery problem. is it new? i'd like to know.
i'm trading mine tomorow and bring home more news
Jul 01, 2009 | Motorola Mobility H670 Headset
Motorola H700 charge issues
The rechargeable battery may have reached it's limit of recharges. You can try leaving it on until you no longer see life (any light) coming from the H700. You want to drain it completely. Than charge it, (take note of how long it takes to reach full). If it dies like before in 15 minutes than the H700 is dead. You can take it to a Motorola store & might be able to exchange it for less than you first bought it. Or you can go here (Click the link) for a new one. http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=Motorola+H700&image12.x=13&image12.y=15
Luck!
Mike
Apr 01, 2008 | Motorola Mobility H700 Wireless Headset
My headset does not hold its charge
Usually Lithium-Ion batteries have a Memory effect, ie. the battery should be 100% consumed then only recharged. If the battery is only 40% used and recharged then the battery will give you only 40% of it's total charge. The battery starts showing you empty after it is 40% consumed even it was 100% charged. Now there is solution for this-Drain battery upto full, store it in a cool place like Frigde then charge it full then again use it upto last. Repeat this procedure for 2-3 times.Your battery should come to normal state. Also check the charging current of the charger.The charger might also be faulty.
Apr 26, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility H500 Wireless Headset Logo
154 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
