Question about Cell Phones
No dail tone - Cell Phones
  • Cell Phones Master
  • 6,993 Answers
you can follow the steps below. The steps below will explain how you can resolve or at least determine why you have no dial tone on your phone. These steps can save money as hone companies are only responsible for their equipment and if they verify that the cause for no dial tone was not their fault, they can apply charges on your bill for such service calls.
  1. If you have a second phone line in the house check to see if that works, if not go to step 2.
  2. If you have a cell phone try calling yourself, and see if the phone rings or if you get a busy signal, or an operator message that can confirm if the phone company disconnected your phone service. If you get a message your phone has been disconnected, call your phone company.
  3. Unplug your phones for at least 15 minutes, all phones in your house and all lines just from the wall jack and power from the cordless phones.
  4. After 15 minutes plug your phones back in the jack one at a time, pick it up and see if there is dial tone. If not the phone might be defective, check the other phones.
  5. If still no dialtone bring a phone to your NID, this is a gray box located on the phone pole (in real rural places) or a gray box that reads "Network Interface", open the box with a flat head screw driver
  6. Once opened you will see some test jacks.
    Disconnect the plug from test jack. If you have more than one line, select the test jack for the line that is causing the problem. This disconnects your inside wiring from phone company's line.
  7. Plug in your preferred non cordless phone into the jack. This plugs you directly into the phone company line.
  8. Pick up the phone check for dialtone and try making a call. If unsuccessful call your phone company and provide them with this information.
  9. If problem is gone, you have trouble on your inside wiring, equipment or jacks. You can call the phone company, a contractor, or try to further troubleshoot and resolve yourself.
  10. Once you have finished your test, disconnect your testing telephone and securely re-insert the original plug. Close the cover and screw the fastener down until the cover is snug and tight.
I wish you good luck.
Posted on Jun 03, 2010
I can not send a fax with samsung scx-4521f
do a simple test. press the onhook button to you hear dail tone. try key in your mobile number and see if you got the call.
if all the above is yes there is no issue with the modem.
if you did not hear any dail tone. check your phone line is it working fine.
make sure that your phone line is not hunting line. fax machine does not work with hunting line. only direct line.
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Our company has a Panasonic kx-t7731 main line has no dail tone.
On that phone, press PROGRAM the button and dial 01 STORE.
Press program again to exit programming.
It's not likely you'll be needing the Group Log In/Out button.
Carl
Mar 12, 2009 | Panasonic KX-TA824PK Phone
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFAX 1840C Plain Paper...
Phone is on pulse when dailing a number
open the on screen menu of the phone there should be a selection for dialing rules.. the tone dialing rule should be in that selection..
Jan 08, 2009 | Uniden Cordless Phone
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
VTECH VT-2406 TONE- PULSE SETTING ?
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=373
Jul 03, 2008 | Vtech VT-2406 Cordless Basic Analog
Modem dialtone problems
Is the phone line going to the modem live?
Jun 25, 2008 | Intel Motherboard
TC1200 TONES/PULSES
There is usually a switch to change it from dial pulse to touch tone.If there is no switch check your user manual to see if there is a screen option.
tk46
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
No dail tone report
some dial connections dont like the filters attached. does the new modem have more then one ethernet connection on it? have u tried it on another connection if u have on in the house? it may just be your settings in the computer. are you using the same computer for both broadband and dial up? if you are then you may need to adjust the settings in your computer, your isp should have done all that for you.
Nov 29, 2007 | Computers & Internet
Cell Phones Logo
110 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
