Question about Microsoft Windows Xp Home Edition English International for PC
Automatic update Just got new system 8 installed a week ago. After installation the first update came. It was to take 3.9 hours to install. After about 3 hours I get this message, System suite8-merge cfg, System suite 8-helper dll could not be checked because of following error (12002) request time out. I hit ok and then next and it starts to redue everything and after about 3 hous it comes up the same problem. Please help. I have a Dell Dimension 2400 series.
  • 813 Answers
Hi friend
so here is your earror report
I'm running WSUS 3.0, not the beta. These errors are on my WSUS server and
promply show when I run: wsusutil checkhealth
All are source: Windows Server Update
Event IDs in order from older to new, but all appearing in the same second.
13042 - Self-update is not working
13002 - Client computers are installing updates with a higher than 25
percent failure rate. This is not normal.
12002 - The Reporting Web Service is not working.
12032 - The Server Synchronization Web Service is not working.
12022 - The Client Web Service is not working.
12042 - The SimpleAuth Web Service is not working.
12052 - The DSS Authentication Web Service is not working.
The server is 2003 standard with sp2.
Originally I was not getting clients to show. I tweaked some folder and IIS
permissions and the clients started show up, but none are receiving the
updates. I've read several articles from MS to see if I can access certain
..cab files through IIS and I can from client machines.
Any ideas or help would be appreciated. Oh, I also installed the 3.0 update
agent and applied the KB927891 afterwards on all machines on the domain
your web serivce is notworking so solve it
Posted on Apr 09, 2008
  • 796 Answers
Are you using windows...
some of the windows updates are trojans....that must be you are seein this problem
How do update my IPOD with ios8
Go to Settings - General - Software Update,
You probably can't though because ios 8 is for newer iPhones, iPads and iPods. If there is an update you get an automatic notification of a red '1' on the Settings icon. I have an older iPod and iOS updates for it ceased a long time ago. I compare against my iPhone 6.
Nov 15, 2015 | Audio Players & Recorders
Tip
How to configure automatic updates in Windows
Microsoft routinely puts out updates for current versions of Windows (and Windows applications). Some of these are critical updates, such as security patches, while others just tweak a program or fix a bug. Your operating system will run better if you stay up to date on the important updates, and an easy way to do this is by using Windows automatic updates.
To turn on automatic updates, right click on My Computer (in Windows Vista or 7, right click Computer) and select Properties. Then go to the Automatic Updates tab. Here you will see the different update options.
The safest choice is to pick Automatic, which will check for updates on a schedule that you choose (daily or weekly, at a certain time) and download any new updates it finds. However, if you want some control over which updates are installed, you can choose either of the next two options:
- Download updates for me, but let me choose when to install them
or
- Notify me but don't automatically download or install them.
If you pick either of these two choices, a yellow shield icon with an exclamation point will appear in the system notification tray when new updates are available, and you can download or install them by clicking on it.
The last option is to turn off automatic updates completely. Choosing this option may leave your computer at risk, because you won't get any security fixes Microsoft comes out with. If you do choose to turn automatic updates off, you should check for updates manually once in a while by visiting Microsoft's Windows Update web page at WindowsUpdate.Microsoft.com.
Whichever option you choose, click Apply at the bottom of the window to save your preference.
on May 28, 2010 | Computers & Internet
USB ports stopped working
If a problem occurs on your computer after you install or update a driver, use Windows Device Driver Rollback to replace the driver with the previously installed version.
1. Click the Start button and click Control Panel.2. Under Pick a Category, click Performance and Maintenance.3. Click System.4. In the System Properties window, click the Hardware tab.5. Click Device Manager.6. Right-click the device for which the new driver was installed and click Properties.7. Click the Drivers tab.8. Click Roll Back Driver.If Device Driver Rollback does not resolve the problem, then use System Restore to return your computer to the operating state that existed before you installed the new driver.
Another cause for this is corrupt registry. I would suggest to use a system utility tool like Reginout to fix this problem.
May 05, 2012 | Fujitsu Siemens LIFEBOOK S7010D...
How to disable automatic updates on XP windows?
To turn on Automatic Updates yourself, follow these steps:
  1. Click Start, click Run, type sysdm.cpl, and then press ENTER.
  2. Click the Automatic Updates tab, and then click to select one of the following options. We recommend that you select the Automatic (recommended) Automatically download recommended updates for my computer and install them option.
    • Automatic (recommended) Automatically download recommended updates for my computer and install them
      If you select this option, Windows recognizes when you are online and uses your Internet connection to find updates on the Windows Update Web site or on the Microsoft Update Web site that apply to your computer. Updates are downloaded automatically in the background, and you are not notified or interrupted during this process. An icon appears in the notification area of your taskbar when the updates are being downloaded. You can point to the icon to view the download status. When the download is complete, you receive another message in the notification area so that you can review the updates that are scheduled for installation.
      • Click to select the day and time for scheduled updates to download and install. You can schedule Automatic Updates for any time of day. However, your computer must be on at the scheduled time for updates to be installed.
      • You can choose to install the updates as soon as they are finished downloading. To do this, click the download message (or update icon), and then click Install. If you choose not to install the updates when they finish downloading, Windows starts the installation on your set schedule.
    • Download updates for me, but let me choose when to install them
      If you select this option, Windows recognizes when you are online and uses your Internet connection to automatically download updates from the Windows Update Web site or from the Microsoft Update Web site. An icon appears in the notification area of your taskbar when the updates are being downloaded. You can point to the icon to view the download status. When the download is complete, you receive another message in the notification area so that you can review the updates that are scheduled for installation.
      • When you want to install the downloaded update, click the message (or update icon), and then click Install to install the update.
      • If you do not want to install a downloaded update, click Details, and then click to clear the check box next to that update to decline it.
    • Notify me but don't automatically download or install them
      If you select this option, Windows recognizes when you are online and uses your Internet connection to search for downloads from the Windows Update Web site or from the Microsoft Update Web site. An Automatic Updates icon and message appear in the notification area of your taskbar when new updates are available to download or to install.
      • Click the icon or message to view the updates. If you do not want to download a selected update, click to clear the check box next to that update to decline it. Click Start Download to download the selected updates. The Automatic Updates icon remains in the notification area of your taskbar while the updates are being downloaded. You can point to the icon to view the download status.
      • When the download is complete, you receive another message in the notification area stating that the updates are ready to install. Click the Automatic Updates icon or the message, and then click Install to install the updates.
  3. Click OK.
For more information about how to schedule Automatic Updates, click the following article number to view the article in the Microsoft Knowledge Base: 327838 (http://support.microsoft.com/kb/327838/ ) How to schedule automatic updates in Windows XP, Windows 2000, or Windows Server 2003
Jun 16, 2011 | Microsoft Windows XP Professional
Application popup: svchost.exe - Application Error : The instruction at "0x745f2780" referenced memory at "0x00000070". The memory could not be "read". Help me to rectify this...
this is a common error if you try to install a new memory card or if you are infected by a virus. if you tried to install/upgraded a new memory card. these are the thing you need to consider - memory card is not properly installed to the memory slot - memory card is not compatible to the system - if you added a new memory card it means that there is a conflict between the old and new memory card
if you did not install/upgraded a new memory card. these are the things you need to consider - you are infected by a worm/virus. try updating your system by installing system updates. install antivirus software - you might install a software that is having an issue with the memory installed in your system. - Operating system is corrupted need to reinstall the OS. - hardware failure try to check first the memory card then hard disk. or just contact local technician.
May 09, 2011 | Intel Computers & Internet
May ask...how to install the new updates windows cause every time i try to install it...it didn't install properly???
1. Stop the Automatic Updates service:
Start > Right-click on Run and select Run as Administrator > (type) services.msc > [OK]
Double-click Automatic Updates > Click on Stop
(Stopping the service will take a moment)
2. Delete the contents of the Download folder:
(type or copy/paste) %windir%\SoftwareDistribution > [OK]
Open the Download folder and delete its contents
Close the window.
3. Start >> Control Panel >> System And Maintenance (If you are using Classic View, skip this step) >> Windows Update >> Select updates to install: Right-click on Update for Windows >> Click Hide Update >> Confirm the UAC (User Account Control) prompt, if appropriate, & OK your way out.
4. Start the Automatic Updates service:
Double-click Automatic Updates > Click on Start
To restore/unhide updates in Windows: Start >> Control Panel >> System And Maintenance (If you are using Classic View, skip this step) >> Windows Update >> Restore Hidden Updates | >>Find and select the update you wish to install >> click on Restore. You can now reselect it and install through the normal process.
Jan 31, 2010 | Computers & Internet
I have a Compac Presario, running VISTA. When
simply disable the automatic update service by following these steps.....
start | run | services.msc | automatic update
stop ...and disable it...click ok
and close the service manager....
then try to shutdown the machine ....
Dec 30, 2009 | Computers & Internet
My PC stopped responding at a normal speed after automatic update was installed
just do a system restore to just before the update took place should solve the issue. if you need further assistance of how to do a system restore please state your version of windows that you are using.
Oct 12, 2008 | Computers & Internet
Microsoft Windows Xp Home Edition English International for PC Logo
150 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
