Question about Casio EX-Z1080 Digital Camera
USB cable is not reading the camera, the cable looks OK no damage
  • 85 Answers
Kindly check the usb port to the camera if disconnected or not.usually the problem always to the port becuase of excessive force inserting the usb cable thats why the contact point of the the said port was unsolder. if its happen try to solder or bring to the service center.
Posted on Jun 03, 2010
My usb cable isnt chargeing my camera, how can it?
Hello Janie,
Please check the connecting points of camera and the USB cable. If all the connectors are good then USB cable is damaged. Purchase the new cable and charge your camera. Another possibility may battery is damaged. So please also check the camera battery.
Dec 26, 2011 | GE Cameras
For some reason the computer cannot find or recognise my camera and keeps saying communication error ?
Ok. there're three possible causes for this. I'll list them and the relevant procedures of resolution by probability of occurrence.
  1. Damaged data cable- (confirmed if the following 2 doesn't fix the problem) if this is the case, you need to get a new cable.
  2. Damaged USB port on computer- Confirm by trying to connect cam to a different port (i.e.- try the rear ports if you were using one on the front) or to a different computer. If this is the case, you need to get a USB expansion card that will give your computer some extra USB ports.
  3. Damage on camera's side (could range from a simple broken port tab to circuit damage) confirm by: connecting a different camera to your computer using the same data cable. If this is the case you will have to take the camera to where you bought it from for repair (remember to check whether you can still claim your warranty.)
Sep 25, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I pushed my USB cable from my Easyshare Kodak camera, into another camera, now my camera wont load pictures onto my PC Can this be fixed by buying a new USB Cable?
That's the simplest and cheapest method of finding out. USB cables are cheap; try another. Hopefully you didn't transfer the damage from the USB cable back into your Kodak. If the USB cable looks damaged, then more than likely that is your problem.
If your memory card in the Kodak can be removed (and the pictures are on it) you can also get an inexpensive card reader (Targus, ~$12 at Walmart) to transfer your images to your PC.
Nov 28, 2009 | Kodak Easyshare M753 Digital Camera
Communication Error when uploading photos
You may have switched USB mode to Pictbridge by mistake.
Press Menu/OK, select Setup, choose USB mode (on 3rd page) switch from Pictbridge to DSC, press OK.
Oct 05, 2009 | Fuji FinePix S1000FD Digital Camera
Looking for usb cable for technika sh-1060 have been in touch with tesco to no avail! thanx, ros
http://www.memoryforless.co.uk/store/erol.html#21423X0
Cable Not available for this camera - Have you considered reading SD/MMC with a USB Reader ?
This device will allow you to read your SD/MMC removed from your camera directly through a USB port on any PC.
It connects directly to any USB port, meaning your images and card can be read quickly and easily direct to your hard drive from windows explorer.
If you need any assistance please contact us directly.
SD/MMC Reader / Writers
If you dont like the above solution and find somewhere that does sell this USB cable...Let me know!! I need one too!
treacs@live.com
Oct 04, 2009 | Cameras
USB Device Not Recognized, Works with Other Camera, Same USB Cable
Looks as if the usb device of your camera? is malfunctioning. Try putting in the MMC/SD/MS Duo card into a dedicated card reader to get the pictures and videos or in the other camera.
In this instance your USB cable is the medium connecting the usb device (camera) to your pc. As the other camera and same cable are working fine this means that both the cable and your pc's usb port are working properly as well. Time for you to change the device from which you are trying to read information from.
Sep 29, 2009 | Cameras
C170 trouble downloading
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 28, 2009 | Olympus Camedia D-425 / C-170 Digital...
Switches off when USB connected to PC
Try another usb connector on the computer.
the camera or usb connector may be damaged.
you can always get a cheap memory card reader for your computer as a fix.
Mar 10, 2008 | Olympus FE-230 Digital Camera
Installation software
try buying a new usb cable on ebay ... look for damage at each end of cable and if somebody streched it to hard well ... get a new usb cable.
if running xp windows you should hear a ding ... reconizing whatever usb u plug into .. if not try a cable and look online for downloads of free software for you camera and updates.
ty
hope this helps
Feb 08, 2008 | Samsung S850 Digital Camera
Olympus fe-130
Make sure your cable is OK. 1: Make sure you don't have any damaged pins on the plug on your camera and on your USB port on the computer Try using a different cable to be sure that is not the problem. If you can t ry a different camera on the same cable and make it work, your camera is at fault. Try it on a different USB port, and possibly also on a different computer to make sure the port on your computer is not at fault. Check both cable ends and the ports on the camera and computer are not dirty
May 18, 2007 | Olympus FE-130 Digital Camera
Casio EX-Z1080 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
