Satelite l200 bios problem
I am puting winxp pro they ask pls cheked hdd is available press f3
  • 472 Answers
If your computer is running a sata HDD, then you may need to install the drivers for the sata controller at the beginning of setup so that your HDD can be found.
F3 is the key used to quit setup, so XP has not found any hard drives.
The other thing to check is in the bios when the computer first boots to see if the hard drive is even being detected by the computer.
If not, then check it has the power and data cables attached.
If the drives are IDE and you have 2 on the same cable,then make sure to set them to master and slave, or both to cable select so they can be found correctly.
Hope that helps =)
Posted on Apr 11, 2008
Windows installation setup says not find any hdd disk drives installed and says cannot continue
You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key. Check if BIOS still recognizes a hard drive. If not, you need to physically reconnect drive and try again.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
No boot device available strike f1 to retry boot in dell optiplex 320 in winxp
Try to replace the CMOS(CR2032) 3v battery, could be the Bios is not function as it should. Set the Bios to settings to default and see whether the HDD is detected in the Bios settings.
If is is no good probably the HDD could be faulty.
Jun 29, 2010 | Dell Dimension 8400 PC Desktop
My computer crashed win7 theme error
try to boot from windows7 cd-rom, without installing it, choose fixing errors.
if impossible at first try,
press F2-button while system boot(before windows takes over),
enter bios-setup and change
BOOT DEVICE PRIORITY to
1st: CD/DVD
2nd: Hard disk/HDD
3rd: (whatsoever availabe)
please remember to exit BIOS saving changes!
(press Esc button after changing the above, confirm: ...Exit bios saving changes ? - Yes)
if you are asked now :
boot from cd-rom or hdd ?
choose cd-rom, let it work and wait.
in the following, do not reinstall windows 7
but choose a repair option,
leave the setup, remove cd/dvd etc from all drives and reboot, wait.
the regular windows screen should show up...
if this does not work, please ask s.o. who knows around with win 7 or think of downgrading from win7 to winxp professional.
as it is older but reliable, still supported and some win-pro's use it.
win 7 features are available but you'll need time to set up the whole system, incl. drivers etc.
this could work...if not ask me to post some links
now retry to boot from Windows 7 CD-ROM,
do not install, cjoose repa
all i can recommend: if you are a bit into computers, think of swapping from windows 7
Jun 13, 2009 | HP Compaq Presario CQ60Z Notebook
How to remove vista from 1525 laptop and install winxp
you have to get in Bios. you will find HDD section. it must be IDE/AHCI section. you need to do IDE if you want to install XP. XP doesnt regognize AHCI SATA drives.
May 30, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
I had to erase my hard drive and re-format it, now when trying to reinstall WINXP PRO, I can't boot from disk. Why is this. Please help
make sure to go into your bios by pressing as its prompted when it first boots up "press F2 for setup" or press "DEL" for setup. go to your boot options or boot sequence and change the boot order. for example if your "HDD" is 1 CD is 2 then change cd to 1 and disable HDD or change HDD to 2. save and restart then make sure the cd is in the drive and when it prompts "press any key to run setup" and press a random key and it will load into the setup of win xp
Jan 23, 2009 | EliteGroup P4S5MG/GL+ Motherboard
Not boot from factory CD -where is CMOS battery?
Appreciate the direct "Ask Me".
Based on your post/description:
  • Toshiba Satellite 1415-S173;
  • new HDD;
  • would install WinXP.
Your concerns are:
  • media/cable fault;
  • CMOS battery;
  • laptop battery.
  • will not complete format;
  • will not install OS (WinXP).
Proposed course of action and other ideas:
  1. double check the new HDD, verify that the pins are not bent and are seated correctly. If all else fails, return the new HDD and have it replaced;
  2. try partitioning/formatting the new HDD in another PC using a 2.5 IDE to USB external adapter;
  3. clean the lens of the DVD/CD ROM drive;
  4. remove the dead laptop battery and use only the AC power when installing;
  5. most current laptops do not use a CMOS battery;
  6. if you want to revert CMOS/BIOS settings to default, it could be done by pressing on ESC or F1 or as indicated in the display (depends on the version) and set all possible settings to default. Verify that it is set to boot from the CD drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 02, 2008 | Toshiba Satellite 1415-S173 Notebook
Cannot Detect Hard drive Winxp On Toshiba Satelite L200
Hi ,
u can not detect HDD during installing win-xp coz in u r laptop u have SATA hard drive.
to detct hdd in setup u want to make sata netive mode diseble in COMS setup
Plz check COMS thereis sata netive mode is available ....
if this information is useful for u please rate me......
Jun 14, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Problem starting my laptop IBM Thinkpad600E 2645
the boot has been corrupted... what did u install lately?? i mean before this problem occured... better use the recovery disk or original OS disk and do a system recovery...
May 22, 2008 | IBM ThinkPad 600E 2645 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
