Question about LG 27LC2R 27 in. LCD TV
I need a sky remote code for the following LG tv: 27LC2R*
SOURCE: Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Posted on Aug 04, 2008
  • 899 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
SOURCE: trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Posted on Feb 18, 2009
EngineerMC
  • 185 Answers
SOURCE: sky remote code for lg m227wdp
press tv button
then red and select together for 2 seconds the led should blink twice
enter the code
press select
try it...
one of these codes should work... but its a bit trial and error 0056 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
good luck
Posted on Feb 14, 2010
SOURCE: need sky remote code for 37lh3000 lg tv please
Sky remote code for LG LH3000 is 0206. This works for the 37" and the 42" and probably for a plethora of other sizes.
Posted on Mar 18, 2010
Got Sky Remote. Need code to make it work on LG TV please
On your sky remote select, interactive.then , sky customer service, then option 5 (programme your remote) follow on screan advice . if you cant find your tv model /make go on the net and google for info.
pete
Nov 19, 2010 | Televison & Video
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Jun 18, 2010 | LG 42LC2D 42 in. LCD HDTV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
I need the code to program my sky plus remote to my new lg tv it is an lg 42pq300
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
Nov 28, 2009 | LG 42PQ30 42 in. Plasma TV
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
Aug 29, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
Trying to set up sky remote with TV (19LG3000)
Dannyboi1940
Nov 24, 2008 | LG M1910A 19 in. LCD Television
Code for sky+remote control for lg tv 50pc56
Haing same problem. Think it's the version of the remote control unit you have. If you have Rev 8 (it tells you inside the back cover) then some codes should work, if rev 6 or rev 4 it can be tricky. Try the following, but can't guarantee anything:
0742 0743 1962 0065 0405 0318 0275 0037 0391 0137 0459 0389 0398 0191 0244 0502 0245 0584 0311 0634 0072 0246 0060 0206 0065 0743
Feb 08, 2008 | Televison & Video
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
TV SETUP CODE
I have found out the solution to this problem.Don t listen to Sky ,just buy your self a latest" series 8 sky plus remote control "and at about £12.00 0n ebay.Then all you do is phone LG customer services with you TV model number.If you have any probs email me at allyballybea@tiscali.co.uk.
Nov 26, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 27LC2R 27 in. LCD TV Logo
60 people viewed this question
Computer Repairing
Computer Repairing
