Question about Canon LaserClass 7000 Plain Paper Fax
Fax doesn't come thru - Canon LaserClass 7000 Plain Paper Fax
    Genius:
  • 2,120 Answers
Do you DSL or any other type of digital phone service?
Try unplugging power cord to get back to AUTO ANSWER
Posted on Oct 06, 2008
Can send faxes but not receiving, comes thru blank piece of paper
What about copies or internal prints?
If even a copy doesn't work then it sounds like your LASER unit has gone out, in which case I'd just replace the machine.
If the internal pages or copies come out but not faxes, and you know the sender is sending correctly, then it could be an issue with the main board.
I'd get a second opinion from a service tech locally but I can at least give you the part numbers for both so you have an idea of the cost of parts.
LASER UNIT
LM4578001
MAIN BOARD
LG6141001
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
Intermittently, the confirmation page on the fax says the fax failed (didn't go thru) but it actually did. Why is this? The confirmation page is printing false results, indicating the fax failed to go...
This is because some faxes don't have Error Correction Mode capabilities.
If there's a slight distortion on the line, the receiving machine (without ECM) receives a fax with some minor errors. And even though for a human eye the resulting fax page is perfectly readable, for the machine, that thinks only zeros and ones, there was an error detected in the data, and hence the trasmission failed.
Faxes with ECM when they detect an error, ask the sending fax to re-send the last portion of data, and this way can bring the transmission to a 100% successful end.
So the only thing you can do is ask your recipients to upgrade their fax machines to an ECM-capable model :)
Oct 29, 2009 | Canon Office Equipment & Supplies
Fax machine rings but fax doesn't come thru at times unless we actually pick up another phone and make a call, at that time the fax comes thru. At other times if we are on the phone, (different from the...
The instruction manuals of fax machines are typically large and complex books. Often there are many options to consider. Mostly the machines can be used successfully without much reference to the manual but when there is a problem the question machine or operator fault can only be determined by thoroughly reading it.
To a large extent whether a fax call is picked up or not depends on the settings (including answering machine), the quality of the phone line and connection and the machine sending the fax as well as the receiving machine.
My fax machine will mostly automatically receive a fax but it seems to miss the important ones and I have to answer the ringing phone, hear the fax tone and press the manual fax button.
I strongly suspect the problem mostly lies with the sending machines - if they are fax machines the results were much better than from a computer being used as a fax machine and while a fax machine will send a receipt, a computer doesn't seem capable of doing so.
Sep 06, 2017 | Brother IntelliFax-4100e Fax
WHEN A FAX IS TRYING TO COME THRU, IT RINGS, THEN BEEPS AND SAYS "RECEIVE ERROR"
There may be some static on the phone line, try a line filter. If possible, you could plug the fax into another working telephone line, and have someone send a fax to that number (whatever number is attached to the new phone jack) to isolate whether or not it is the machine, or the wall jack.
May 20, 2009 | Samsung Office Equipment & Supplies
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
Can't send a fax.
You need to have a phone line not just internet connection to send a fax. Unless you have an account with a fax to email company. So you need to hook your fax machine up to your already exsisting phone line, get a seperate phone number for fax purposes or serch the internet for a fax via email company.
Jan 14, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lines going thru the pages of fax i send
you ma try to make a copy see if have lines through the page if does, you may go to document feed unit open the cover you may see a piece glass just use alcohol to clean it should take care your problem
Dec 13, 2008 | Dell 1815dn All-In-One Laser Printer
How can send fax thru internet
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
Fax problem
my computer is connect thru the cable and my fax i don't know how to set it up thru the computer
Aug 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
46 people viewed this question
old marine
old marine
