Question about SanDisk Sansa e250 MP3 Player
Sansa e250 mine is stuck on refresh database
  • 10 more comments
  • Anonymous Apr 09, 2008
    My mp3 is also stuck on refresh database and don't know what to do. I tried taking out the battery and nothing. I also tried shutting it off for a while and still nothing. Every time I turn it on it still says refresh database. Someone please help! Also, I tried plugging it back in to the computer to see if I could figure something, anything and I noticed that when I went into my computer I didn't even see an icon of my mp3 on the device section. So what now?
  • thubatisrinu Nov 14, 2008
    reset database problem
  • igp1sg Jan 14, 2009
    i keep getting an error code 1003 while trying to download the driver for an e250 sandisk mp3 player i am having the same problem as the person above, freezing up at refresh database can anyone help
  • claudialili Jan 14, 2009
    My mp3 player stuck on the refresh database screen, then the restart and happen again!
  • Anonymous Jan 16, 2009
    Mine is stuck on a black screen...anytime I plug it in to charge it the circle thingy turns blue and doesn't shut off until a long time after. My mp3 won't turn on at all. It's like froze? What do I do?
  • Anonymous Feb 05, 2009
    i cannot reset it
  • Anonymous Feb 08, 2009
    my mp3 player is stuck on the refresh database screen. i hold the off button for 15 sec., it urns off, i turn it back on and it is still stuck on the same refresh database screen
  • Fleming3930 Feb 09, 2009
    I had this problem with my e 250, and I took the advice. But when I got to the SanDisk site, it would not give me an option to download the latest firmware. Actually, it didn't give me an option for a firmware download of any kind. Instead, it wanted me to download the Firmware Updater, which was supposed to find all of the updates specifically for my player. So, I went ahead and downloaded it. It will load up, and it says that it recognizes my device, but it only does this for a few seconds then the thing tells me to contact SanDisk tech support with the error code #1003. Everything worked just fine up to this point. Did I download the wrong thing? I am kind of at the end of my options for this player, and it is just my luck that it decided to do this after the warentee ran out. But this sounds like the way it works from what others have posted. I can only hope you have other options for me to try as these failed.
  • jonathanadam Mar 04, 2009
    At first while I would be listening to a song the screen would just turn white and I would have to turn off and turn back on the mp3 player to get the screen back to normal. Later, I started to have trouble turning on the player, having to press and hold the power button severval times just to turn it on. Now When I try to turn it on the screen says refresh database and I don't know what that means.
  • Anonymous Apr 06, 2009
    my sansa e250 as the same problem it wont go passed the refesh database screen and it gets half way and stops and thats all it dose
  • mayleen_rive May 11, 2010
    for the recovery solution, what if i can not put my mp3 in msc mode?
  • habfan_9 May 11, 2010
    how do i get out of the recovery mode, the screen is black with some small writing on it, thanks
  • 4,102 Answers
Hi follow these instructions ok
1 with mp3 player off switch lock/hold to on
2 press and hold down rec button on left hand side keep holding down
3 switch on whilst still holding down rec
4 it should now say recovery mode
dont do nothing just yet dont connect to computer ok first goto sandisk website and download the latest firmware once downloaded open the file and it will tell you how to install this onto mp3 player.
you should no longer have your problem
let me know how you get on and also if you need further assistance ok
Posted on Apr 09, 2008
Awesome!! It worked!! thanks!!
Posted on Jan 25, 2009
SOURCE: Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Posted on Aug 24, 2006
mixmaster
  • 626 Answers
SOURCE: refresh database message
Run the recovery tool from the SanDisk website. Make sure you select format when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Sep 10, 2007
SOURCE: Sansa e250 has Refresh Database Frozen
Look at this site:
http://www.expansys-usa.com/ft.aspx?k=89682
follow the steps showed by MrSinister27
It worked for me!!
Posted on Jul 23, 2008
  • 5 Answers
SOURCE: Sansa e250 stuck on "Refresh Database"
yOU HAVE TO ****
Posted on Mar 14, 2009
  • 102366 Answers
SOURCE: My sansa e250 always get stuck at refresh database
Take out the MicroSD card. Turn it on. When it comes on, turn it off. Clean the contacts on the card and reinsert. Then try turning it on again.
Posted on Jan 14, 2010
My Sansa e200 will turn on, thumbwheel is blue and SanDisk screen comes on, but menu won't come on. I have pressed and held the power/menu button down for app. 15 seconds several times to no avail. It is...
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
Sep 27, 2009 | SanDisk Sansa e250 MP3 Player
Refresh database
Did you try reseting it?
May 25, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E200R gets stuck in refresh when I turn it on
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
SCREN LOAD MAIN IMAGE FAILED SWITH TO RECOVERY MODE
WHAT HAVE ?
Sep 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database
try taking out the battery then put it back in then turn it on. that should do it.
Aug 14, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
886 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
