Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
It does not clean well. my uncle took out the
It does not clean well. My uncle Lee took out the bottom sprayer and cleaned that and it was a lot better but my old dishwasher cleaned better and it was 20 to 30 y/o. also I want to fix it. i have called 3 to 4 people out and they did nothing. help
  • 166 Answers
Improper loading can sometimes cause this problem.
On most models, a wash tower rises through the center of the bottom rack during the cycle. Do not block the circular opening through which this tower rises. Also make sure your water is hot enough. at least120-150 degrees F. you may also try running the hot water at the sink before starting the dishwasher.
Posted on Jun 03, 2010
I have lots of pressure in the tank but not much is coming out. I need a picture of what to clean please. Gerry
Try taking apart your trigger and tip and cleaning them. Then try again see what happens.
Aug 20, 2010 | Solo Backpack Sprayer 5 Gallon
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishwasher not cleaning dishes
Aug 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Dishwasher that leaves dishes dirty
Your drain could be blocked, remove the drain from the trap below the sink and try running the unit on drain, into a bucket. Also check the connection at the trap to ensure it is free from blockage
Mar 19, 2009 | Dishwashers
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Sprayers Will not work.
so what is the problem fills but wont spray
Dec 10, 2008 | Maytag MDB9600A Jetclean II Built-in...
Soap stuck in dispenser/dishes not getting clean
try and find a manual to assist you, pdfoo.com , but most ot the sprayers have clips that hold them on/in. just be carefull not to break any.
Jan 21, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
443 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
