Question about Durabrand Portable DVD
Main unit will not even turn on
We got
On my pdv-722 there is a separate switch for the lcd screen to turn on or off along with the power switch.
Posted on Apr 20, 2008
Trouble C-5102 Open & Close the front door to reset?
Open the front door and pull out all four image units not the toners. once out separately shake each image unit along its axis you want to have the developer and toner inside each image units to be evenly spread along the axis of the image units so that the motor that turn the drum and developer are not forced to turn with all the developer sitting at one end, hopefully the main motor is not burned out or worse case the main board is shot. Store all image units and toner horizontal not vertical..open close front door Might also have to replace the four image units if the hard to fig which drum might not be turning
Apr 11, 2014 | Konica Minolta bizhub C250 All-In-One...
C-5102 Open and close the front door to reset however alarm still up
Open the front door and pull out all four image units not the toners. once out separately shake each image unit along its axis you want to have the developer and toner inside each image units to be evenly spread along the axis of the image units so that the motor that turn the drum and developer are not forced to turn with all the developer sitting at one end, hopefully the main motor is not burned out or worse case the main board is shot. Store all image units and toner horizontal not vertical..open close front door Might also have to replace the four image units if the hard to fig which drum might not be turning. Open close front to reset after all of this
The sound is not working even with the volume up on 30 no sound
Be sure you have audio input to unit, then be sure you have the speakers turned on in the unit menu; if still no sound most likely the Main PCB; could possibly be the speakers, but more than likely the Main PCB as long as you have the 5, 12 or 15 volt source
Nov 26, 2013 | Sansui 19 in. LCD TV
Fusing unit setting error
To prevent damage to the machine, the main machine cannot be operated until the fusing related
SC has been reset by a service representative.
? Enter "SP Mode 3" in the SOM.
Click "OK" in "Reset Fusing Unit SC" with "SP Mode 3", and then turn the main power switch off
and on.
Dec 11, 2011 | Ricoh Aficio 2228C Copier
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
Condition
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
Sep 23, 2009 | Canon imageRUNNER 8500 Copier
I just purchased an Airwave AT-1000 headset model and I cannot even get it turned on.
If you have followed the instructions explicitly - the unit could be faulty..
I would suggest bringing it back for an exchange of another one.. Don't wait too long - return time policies are short on electronics..
Good luck !
Aug 14, 2009 | Audio Players & Recorders
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
PS3 - No main menu
Contact Sony @ 1-877-253-SONY(7669) for a replacement unit as this is not normal.
It autoplays games but no main menu eh?
Sep 08, 2008 | Sony Playstation 3 (PS3) Console
Unit will not turn on
I realized your problem. i think the problem is the main board of your unit. pls spicify the model and brnd.
Nov 16, 2007 | E-Machines Emachine T5026 power supply **...
JVC TH-M505 powers off right away
The unit is going in to shutdown. My guess is a failed output. Service is going to be required.
Sep 20, 2006 | JVC TH-M505 System
Durabrand Portable DVD Logo
78 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
