Question about Philips CDR880 CD Player
Opc fails On new blank 80 minute cd's the opc test fails. Older 74 minute cd's worked and I have found a few Sony cd's made in Austria that work, but these are no longer available and only some of them worked. My guess is the firmware needs to be updated to increase the opc range. Is this possible?
4 Suggested Answers
  • 112 Answers
SOURCE: trouble with cdr 570 philips
Newer discs are made with different dyes. We no longer get philips discs in the UK but Maxell 80 min discs work great in my 570. Have you ever been able to use 80 min discs? Usually if a machine only accepts certain types of disc it means the laser's power output is reduced i.e it's worn out so it may be time to find a new machine unless you can get a supply of discs it does use OK.
'Mr Audio' discs from Mr Data should be avoided at all costs.I can only use them in my Sony machines.
Posted on Feb 29, 2008
SOURCE: philips cdr 760 cd recorder: OPC FAILED
I have a Phillips 775 CD Recorder, and can only get it to record using Maxell CD-R Music Pro brand blank discs. They usually come in packs of 10 and are in full-size jewel cases. Haven't bought any in awhile and am not sure about availability.Hope this helps.
Posted on Sep 05, 2008
  • 3 Answers
SOURCE: I have a hardtime finding blank CD RW that work
Hi!
I have the same problem too. Tried with, of course only audio cd, TDK (no-opc rate approx 80%), Philips (40/50% and sometimes not good quality on different readers). The best, i.e. less no-opc rate, I found are Sony Premium.
Sometimes it's ok if after no-opc you turn off and restart with test (play+stop+turn on).
Posted on Nov 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a philips
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Posted on Jan 30, 2011
I have a Phillps 870 CD rcorder. Have been using TDK Music CD-RW, 4x, 700mb discs. Just bought new discs from same manufacturer and sames epcs but get OPC FAILED message
Welcome to Fixya.
OPC stands for Optimum Power Calibration. basically, it's a small test to write on the media and read it back for self calibration of the laser power.
I'd try different blank discs to see if it's sensitive to some. Of course they recommend only Philips brand but most major brands should work. Sometimes the "times x" recording rating needs to be higher or lower.
You can also try to turn unit on at least 30 minutes or more before use (this seems to work best for me)
The bottom line is that certain media and certain writers just don't get along, so there are no permanent "Fix" for this issue as every CD recording device encounters such once in a while.
Here's an excerpt from one of the tech members who experienced this problem :
"If I have an OPC Fail message, I try another blank. If
good price..."
Hope this helps, Thanks for using Fixya.
Jul 09, 2011 | Audio Players & Recorders
I don't founr cd 74 mn 650mb, what use the DENON CDR M30 ??
If I understand your question, it can play any kind of music CD but it can only record on CDR-Audio or CDR-Music discs only.
• Only audio CD-R/RW discs can be recorded with this unit. "Use Audio CD" will be displayed when a disc other than one
for use with audio such as a CD-R/RW disc for use with a personal computer or another type of disc is loaded. (See "Discs that Can Be Used with this Unit" on Page 5.)
• CD-R discs can be recorded to only once. The recorded information cannot be erased.
• The recorded information of CD-RW discs can be erased. When this disc has been finalized, erase after the finalization removal operation has been performed. (See "Cancellation of CD-RW disc finalizing" on Page 28.)
• Recording mistakes made with CD-R discs cannot be erased; therefore, it is recommended that a CD-RW disc be used until you are accustomed to the recording operation.
If you desire 74-minute blank disc just Google "cd-r audio 74". The unit will also use 800MB 80-minute CD's.
Jan 31, 2011 | Denon CDR-M30 CD Recorder
I have a philips audio recorder cdr 760 When i try to record cd rw a blank audio tdk cd the machine said OPC FAIL What I have to do to record the cd rw on my Philips cdr 760 Thanks for your...
The manual:
Discussion online:
good price..."
Hope that helps "
Jan 30, 2011 | Philips CDR760 CD Player
A cdr630 twelve years old will not record on any blank discs optical fail on maxell tdk and all brands.do you know what discs i can buy for this machine.marantz state discs with a green dye but i cannot...
The manual states that 74 minute 650MB 1-4X disks run best; my machine would not burn anything I had, eventually I found 650MB crrw's on ebay for as cheap as 2 cents a piece, I have a fair number of them and so far every single one has worked. Imation 800Mb cd's seem to work 80% for me.
May 20, 2010 | Marantz CDR631 CD Recorder
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
No Upc
Do you mean "no-opc"? If so, try:
- turn off and on again;
- turn off -> press play+stop while turning on (this tests and after few minutes should say "passed" (if not, technical service needed);
- try other audio CD (the best I found are Sony Premium).
Oct 16, 2009 | Philips CDR765 2-Disc CD Recorder
Hi!
Oct 11, 2009 | Philips CDR765 2-Disc CD Recorder
Trouble with cdr 570 philips
Feb 24, 2008 | Philips CDR570 CD Recorder
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
Philips CDR880 CD Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
