Question about Intel Motherboard
D11020M_ motherboard manual and maximum system memory it supports
    Sergeant:
    Novelist:
  • 172 Answers
Hi puneeth_kb1. Probably you have had problems looking for it online because that is not a correct motherboard model... Intel's usually go by the chipset such as Intel 82945G or 965 something like that. so look for that type of name on the motherboard. Usually between the CPU and memory modules. I hope this helps.
Posted on Jun 03, 2010
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Will my motherboard(D945GCNL) support 4 GB RAM?
No. The maximum that your motherboard will support is 2 GBs of RAM. 1 GB on each slot. Refer to this link: http://www.crucial.com/store/listparts.aspx?model=D945GCNL
Apr 11, 2011 | Intel D945GCNL Motherboard
How to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Jan 31, 2011 | EliteGroup GeForce6100PM-M2 Motherboard
I have inserted a 1 GB mamory modual and the system is not reconizing the additional memory. Are there jumpers or switches that need to be reset?
No jumpers or switches need to set. If your going to upgrade/change your memory, just make sure that the memory your're going to insert are compatible with your motherboard. Check the system bus of your memory slots if what are the maximum system bus can support of that motherboard. Like example; DDR PC266 to PC400 or PC400 to PC800, make sure that you are not exced the maximum requirements of the memory for your motherboard it is because they cannot recognize your memory.
Jun 03, 2010 | AOpen s661FXm-7US (918EM10S6G) Motherboard
Does this motherboard support ddr400
Yes, this does support ddr400, there are two memotry sockets on the board they will hold 1 gig each you could try a 2gig stick in each but according to the spec on the board it only takes upto 2gigs of ram.
Jan 31, 2010 | Intel D845GVSR Motherboard
Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
Intel® Desktop Board D102GGC2 - System Memory Features:
The board has two 240-pin DIMM sockets and supports the following memory features:
1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
2 GB maximum total system memory
Minimum total system memory: 128 MB
Non-ECC DIMMs
Serial Presence Detect
DDR2 533 or DDR2 400 SDRAM DIMMs
Jan 12, 2010 | Intel D102GGC2 Motherboard
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
What is the maximum onboard VGA support from Intel D865GBF?
This board supports uses Intel Extreme Graphics 2 for its onboard video memory but even Intels site does not explain how much memory it has or if it shares RAM for video memory. Your manual can be found here
http://www.intel.com/support/motherboards/desktop/d865gbf/sb/cs-008983.htm
May 12, 2008 | Intel D865GBF Motherboard
Intel Motherboard Logo
1,311 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
